700r4 Tranny Problem
Old Mar 16, 2007 | 01:11 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
My transmission will not do anything in any of the gears when i step on the gas. No matter what gear i put it in, it will only rev but not go anywhere. Does anybody know what the problem might be and maybe how to fix it?
Old Mar 16, 2007 | 01:15 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
First confirm that the shifter cable and linkage is firmly attached and properly adjusted. Next, take the cover off of the bottom of the torque converter area and be sure that all 3 15 mm bolts are tight and holding the torque converter firmly to the flexplate. If this checks, you have a bad trans, torque converter or both.
Old Mar 17, 2007 | 01:44 PM
'89 Iroc's Avatar
I broke the gear in the front pump and it acted the same way. It is a common problem on 700r4's. I dont know the proper way to check it, but if you dont see the two teeth in your front pump after pulling your tc, could be your problem
Old Mar 19, 2007 | 05:37 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Im thinking about just pulling the tranny and looking at it from there. I found a 700r4 for it but it is out of a 6 cylinder. Will this work in it. Are there any differences between a v8 and v6 700r4?
Old Mar 19, 2007 | 07:17 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
They have a different Bell Housing and Won't work
Old Mar 21, 2007 | 03:30 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Re: 700r4 Tranny Problem
Could the TCC solenoid have anything to do with this problem.
Old Mar 21, 2007 | 03:45 PM
No
Old Mar 22, 2007 | 07:27 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I took the cover off and could not find the three bolts floor guy was talking about. Where exactly are they. I also noticed that the linkage has very slight side to side movement. Is this normal
Old Mar 22, 2007 | 08:51 PM
rv1890's Avatar
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
The bolts hes talking about is what holds the TC to the flexplate. When u take that inspection cover off you will see ur flexplate and teh TC. In the middle are (3) bolts. Make sure they are in taact. Sometimes they can break off. Also try to spin the convertor. It will be tough, but try. The TC and the flexplate should turn together. If they dont u have a problem.
Old Mar 22, 2007 | 08:58 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Should the car be in drive when i try to spin the converter or doesnt it matter.
Old Mar 23, 2007 | 06:19 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
NO!
When the engine is running, the converter will be spinning 600 rpms or more.Sticking your hand in there will tear it off
Do Not take this the wrong way.
In the name of safety, I suggest towing the car to a shop and getting a pro diagnosis.
The automatic transmission is the most complicated piece of equiptment on the car, thus not easily repaired or serviced by the average guy.
Without having the basic understaning of the parts, and how they work, you could be badly injured trying to diagnose it.
Safety first.
Old Mar 24, 2007 | 06:12 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I wasnt gonna check it when it was running.
Old Mar 24, 2007 | 06:15 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Also as i said before, the linkage has very slight side to side movement. Is this normal. I tried tightening it and couldnt get it any tighter.
Old Mar 25, 2007 | 11:51 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
My torque converter i not bolted to the flywheel. This is gonna be the solution. Can anybody tell me what size the 3 torque converter bolts are? I Know from floorguy that they are 15mm but does anybody know the length?
Old Mar 25, 2007 | 06:32 PM
vincode8's Avatar
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
The factory bolts had 15 mm heads and were aprox 3/4" long. If you need some let me know. I have some lying around.
Old Mar 25, 2007 | 08:26 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
ill see if i have any that will work. if not ill let you know.
Old Mar 27, 2007 | 05:39 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Bought the bolts for it. Thanks anyway
camaro11j
Sep 19, 2018 08:49 AM
Thornburg
Aug 25, 2015 01:46 AM
spaigo
Aug 21, 2015 07:46 PM
TreDeClaw
Aug 14, 2015 06:58 PM
drathaar907
Aug 6, 2015 04:20 PM
