Wire on 700R4
Old Apr 2, 2007 | 08:46 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
Wire on 700R4
Ok guys help....I have a 2 connector wire (With a push on connector) hanging down near my tranny...(At least I think it goes there) It is hooked into the other multiple connector wire that is on the tranny.....Im not sure what it does, but it has been unhooked for a while now, as there is dirt in the connectors.....WHERE DOES THIS GO????? I thought it might be for the lockup, but just dont know.(Never thought it worked)...What are the wires for on the tranny...????? Is there anything else it could go to???? I have tried everyplace I can think of, but can find no places that are missing anything..I guess what I need to know is what are the wires under the car...I never noticed it, till i put a new shifter in...Thanks for any help on this...Tom
Old Apr 2, 2007 | 09:10 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Wire on 700R4
What color are the wires? It's probably for the VSS.
Old Apr 2, 2007 | 09:26 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Re: Wire on 700R4
VSS, what is that..????..My speedlimiter worked, untill it was chipped, and my speedo works fine.Forgive my stupidity....
Old Apr 5, 2007 | 04:38 AM
Pat Hall's Avatar
Re: Wire on 700R4
My 89 RS has the same connector. It's just an extra connector that's not used. I'm pretty sure it's for the VSS, which isn't used unless you have the electric speedometer, which wasn't used until 1990. The only other thing it could be is the reverse light connector for a manual trans. They have the same style plug as the VSS. Either way, it's not used for anything. That's the way they came from the factory. Btw, VSS stands for "vehicle speed sensor". Our cars have a different form of VSS though. It's located on the gauge cluster in the back of the speedo head. It's just a data input for the ecm for torque converter lockup, or the shift indicator light on a manual car.
Old Apr 5, 2007 | 07:15 AM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Re: Wire on 700R4
Ok, I was kinda thinking it was extra....Makes sense....Thank You very much, Tom
jklein337
Sep 19, 2018 06:23 PM
camaro11j
Sep 19, 2018 08:49 AM
stalkier
Dec 6, 2015 11:25 PM
Reddeath210
Oct 6, 2015 08:20 AM
g.l.mos
Aug 22, 2015 12:02 AM
