stator shaft removal
Old 04-07-2007, 09:29 AM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
im in the process of rebuilding my 700r4. i need to know how you remove the stator shaft from the pump housing. is it pressed in or is it just a tight fit. is there a special tool for the job. any help would be great.
Old 04-07-2007, 09:55 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: stator shaft removal
it's a press fit. if you're not careful, you could warp the housing removing or installing it.
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
HP52TA
02-03-2018 10:51 PM
MY87LT
Aftermarket Product Review
06-07-2016 09:47 PM
dbrochard
10-03-2015 12:43 PM
dbrochard
09-07-2015 09:41 AM
Quick Reply: stator shaft removal
