Do I need a different stall
Old Apr 10, 2007 | 10:09 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Here's my DD2000 hp/tq table.
Right now I have the stock converter in my 92 350 GTA. I'm getting the Pro-built street/strip rebuild kit and was wondering if i'm going to need a stall.
Do I?
What benefits would I see with upgrading my stall?
What can I expect using my stock stall?
Driveability?
It's mostly a street warrior with the occassional dragstrip day. Also sees nothing less than a perfect day.
Old Apr 10, 2007 | 10:39 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Do I need a different stall
It pretty much depends on your cam. Whats your cams power range ?
Old Apr 10, 2007 | 03:08 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Custom cam. Thunder Racing didn't inform me of a power range.
specs:
.531/.534 224/230 112+4 lsa @.050
I'm running 1.6rr
Old Apr 10, 2007 | 03:23 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
I would be guessing around a 2500-3000 stall for that. That is a roller cam correct?
Old Apr 10, 2007 | 03:36 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Just got off the phone with CompCams.
They said the range on this roller cam is 2000 - 6200.
Old Apr 11, 2007 | 08:19 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Converter math seems to be kind of in the same ballpark as cam selection. Any suggestions?
Old Apr 11, 2007 | 08:38 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
I would say about a 3,000 stall should get you right in your powerband.
Old Apr 11, 2007 | 12:14 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Seems high to me but then I don't know much when it comes to this.
The only stall I ever put in was for a 92 Talon TSi AWD. It was a dog off the line.
What can I expect driveabililty and streetability-wise with a 3K stall? Mileage?
Old Apr 11, 2007 | 12:38 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
3000 sounds high but it actually the conveter will stall around there probably give or take 200 or 300 rpm depend on your motor. I have a 3000 stall and it drive's fine and streetable. Just because its a 3000 stall dosent mean it will launch a 3000 all the time it just it "flash " point when you mash the gas.
Old Apr 11, 2007 | 12:43 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
For my info:
What difference would there be between the 3K stall and say a 2400 stall?
Old Apr 11, 2007 | 12:50 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
The difference is when you mash the gas your conveter would stall to around those rpm's. That's why you want to match your cam powerband to your torque converter. So the coverter will stall where your making power.
Old Apr 11, 2007 | 12:57 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
According to the dyno sheet my fly hp increases about 50hp per 500 rpm.
230hp @ 2500
280hp @ 3000
So a 3K stall should stall at 280hp? Why wouldn't I want it to stall around 2500? Stock my car had 245 fly hp.
Just trying to fully understand this voodoo.
Old Apr 11, 2007 | 01:05 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
The stall speed is up to you. You can go either way 2500 or 3000 stall. It just how far in your power band you want to be in.
Old Apr 12, 2007 | 02:56 AM
jagevileye21's Avatar
Car: 1991 Z28 Vert
Engine: LT1 350
Transmission: T56 6 Speed
Axle/Gears: 3.42 LSD
84 z28 The stall speed is up to you. You can go either way 2500 or 3000 stall. It just how far in your power band you want to be in.
Is it better (more performance wise) to stall around the same RPM as you power band starts or maybe 500 to 800 RPM's into your powerband?
Jay
Old Apr 12, 2007 | 07:28 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
You want to be a little into your power band not when it starts
Old Apr 12, 2007 | 09:34 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Interesting. And makes sense.
Does everybody agree with a 3K stall? Opinions?
Old Apr 12, 2007 | 02:26 PM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
im running a 3500 stall with a 224/230 .503/.510 112lsa and it works fine... have to rev it a little higher to get up to speed but once it locks up from what i here it feels like a stock converter...(im still trying to get my lock up to work)
Old Apr 13, 2007 | 06:57 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I gave Dana a call. He suggested a 2800 with my driving and my gears. Sounds good to me.
Now I have the street/strip rebuild kit, trans cooler, and 2800 edge stall on the way. More fun. :lala:
Old Apr 13, 2007 | 08:23 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Sounds good, that will be a blast to drive. Try not to hurt too many mustangs !!
Old Apr 13, 2007 | 08:27 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I have plenty of Mustang kills. Now I can actually play with the new GT's.
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
amcnellis
Sep 16, 2015 04:16 PM
