Manual tranny shifter
Old Apr 10, 2007 | 06:21 PM
rodie_27's Avatar
Car: '89 IROC convertible
Engine: 355 TPI
Axle/Gears: 3.45? Posi
Ok, here's the deal. I just bought a '89 IROC with a manual trans and am in the process of fixing it up. I just had to take it out the other day and drive it and found that when I got on the accelerator pretty good, the shifter **** lifts up considerably. It kind of freaked me out at first, but now I just don't know what's up. If I don't get on it too much and drive it easy, nothing happens. Anybody know what's going on?
Old Apr 11, 2007 | 09:51 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Re: Manual tranny shifter
tranny mount
Old Apr 11, 2007 | 10:06 AM
j dezzy's Avatar
Car: 87 TA
yup. same thing with my 84 TA when I got it. $12 part and the problem is solved.
Old Apr 11, 2007 | 12:44 PM
rodie_27's Avatar
Engine: 355 TPI
Hey guys, Thanks a lot! That's great news, I was beginning to get a little stressed and freaked out about the whole thing. I definitely came to the right people!
Old Apr 11, 2007 | 03:15 PM
ttypecamaro's Avatar
Car: 09 Cobalt SS Sedan. 92 Z28 vert
Engine: 2.0T EFR6758; 5.0TT T3/T4 8psi
Transmission: F40; 700r4
Axle/Gears: 3.76 LSD; 3.23 posi
the reason it lifts up is because the torque arm is trying to rotate upward to counter-act the force of the tires on the ground. When the tranny mount gets old or overloaded you feel the shifter raise up. If you plan on beating on it a lot or plan on making a lot of power, get a polyurethane mount, a solid mount, or get a crossmember with a torque arm mount.
Old Apr 11, 2007 | 04:11 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
napa has the rubber one for about $12-20. I'd recommend a polyurethane one. Most of the polyurethane suspension companies have them. Prothane, ES, etc.
Old Apr 11, 2007 | 04:35 PM
j dezzy's Avatar
Car: 87 TA
yeah. Polyurethane will last A LOT longer than a rubber one. the rubber one I put in my camaro didn't make it 2 years.
Old Apr 11, 2007 | 04:42 PM
rodie_27's Avatar
Engine: 355 TPI
Ok, great! So this is all I'll need?
http://www.oreillyauto.com/EW3/Produ...20V8-5.0L%20FI
And this will work with my 5-speed? I'm pretty sure it's a T-5, but haven't checked to be 100% sure. Once again, I appreciate all the input.
Old Apr 11, 2007 | 04:47 PM
j dezzy's Avatar
Car: 87 TA
the link to me to a store locator page.
Old Apr 11, 2007 | 04:49 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Just as j dezzy said, go with a polyurethane. They are alot more dependable than a rubber mount. Besides they arent that exspensive.
Hotrodboba400
Dec 10, 2019 07:07 PM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
