After installing a trans cooler did you dipstick reading seem to be off?
Old Apr 11, 2007 | 06:11 PM
jagevileye21's Avatar
Car: 1991 Z28 Vert
Engine: LT1 350
Transmission: T56 6 Speed
Axle/Gears: 3.42 LSD
Every since I installed my trans cooler my dipstick readings seem to be off. When the car is cold sometimes fluid is alittle above the hot mark on the stick. Then sometimes when the car is hot and I check the fluid it is barely in the cold marks. I have a 4L60E out of an Trans AM and I have my oil cooler installed in series with the radiator.
Did this happen to anyone else? Is it normal?
I don't want to hurt my trans so if someone could help me out that would be great.
Thanks in advance,
Jay
Old Apr 11, 2007 | 07:17 PM
Cornholio7979's Avatar
Car: 89 Formula, 89 IROC
Engine: GMPP 350 HO, L98
Transmission: 4l60x2
Axle/Gears: not enough, good enough
Re: After installing a trans cooler did you dipstick reading seem to be off?
My dad has always told me to check the transmisison fluid when its at operating temperature. Nobody has ever told me different, or the same, so i'd rather the trans have enough fluid when it's running than sitting. I think when it runs, the fluid gets sucked around and pressurized into lines which leaves a little less in the pan.
Old Apr 11, 2007 | 07:48 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Check it when its at normal operation temp. In park or neutral. Fill it up to the HOT mark on the dipstick.
Old Apr 11, 2007 | 08:25 PM
Gallileo60's Avatar
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
It should not make a bit of difference, once it is filled up......It will take a little more depending on the size of your cooler....
Old Apr 11, 2007 | 10:06 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
check it when the motor is running in park, typically after a little drive to warm it up.
Old Apr 12, 2007 | 02:35 AM
Car: 1991 Z28 Vert
Engine: LT1 350
I checked it in park @ normal operating temp and it still read low. So I'm guessing I need to add some fluid. However, if I do that when its cold it will be way pass the hot mark.
Is the hot mark the only one I should be concerned with?
I just don't want to hurt my trans.
Thanks,
Jay
camaro11j
Sep 19, 2018 08:49 AM
maroe624
Apr 16, 2017 08:29 AM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
Leggman1
Aug 6, 2015 04:15 AM
