9 bolt axle shafts? help!
hey guys, ive got an 89 trans am gta that I bent the right hand axle on. Went and got an axle from the wreckers, went to install it and it was the wrong one. Its a 9 bolt with disc brakes , Apparently they changed the design half way through the year or something? does anybody have any info on this or know what years of axle will work in my rear end?
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
Re: 9 bolt axle shafts? help!
I am not familiar with "different" 9 bolts. They were all the same, shy of the brakes, and 2/3 series carriers. The axles are different length though from passenger to driver side. IIR they are about 2inches different.
shawn
shawn
I have an 89 gta 9 bolt rear end that I am parting out.
I do have the axel shafts for sale.
If your interested, PM me..
the price is $50 usd each + shipping from toronto canada.
let me know
let me know
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
9 bolts never had C clips. The same axles were used regardless of brakes.
what do you mean by 2/3 series carriers, not totally sure what a carrier is haha, thanks.
Last edited by gtaanyone?; Apr 25, 2007 at 12:28 AM. Reason: Automerged Doublepost
Engine: 383 Carb
Transmission: 4L60
There were no changes in 9 bolt axles. 10033571 for the left and 10033572 for the right were the only axles used for the entire run of 9 bolts from from 85 to 90, regardless of disc or drum brakes.
Not to argue, but then why doesnt any 85-90 9 bolt axle out of a camaro / trans - am fit in my car? Already had to take a 89 gta 9 - bolt axle back because it was a different style. To my knowledge the disc and drum axles are different, can anybody back me up? I'll try and find a pic i guess..
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i didnt even know 9 bolts came with drums as i thought the 9 bolt was a high performance option only with J65 disks
but i also heard there is no difference. i have a 89 rear end parting out as well. my axles are in great shape but i'll check them next time to see if they are different right to left. i didnt take notice to anything last time
Engine: 383 Carb
Transmission: 4L60
not totally sure haha, it could be a screw up by the junkyard guy i guess. You seem to be knowledgeable about axles so could you tell me which t/a's and camaros came with a 9 bolt for what years? And if 9 bolt did come with drum brakes? any info would be great thanks
Engine: 383 Carb
Transmission: 4L60
Look for T/As and IROCs from 86 to 89. The Parts & Illustration Catalog specifies J65 rear discs for the 9 bolt housing, and has no listing for J50 rear drums, so it's possible that the 9 bolt wasn't offered with drums.
The 9 bolt is uncommon enough that most junkyards probably won't even know that there even was a different rear available, unless they deal specifically in F-bodies.
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
the 9 bolt did come with drum brakes on very few cars. I actually saw a 9 bolt with 2.77 and drum brakes in an 89 iroc.
Car: 1992 trans am convertible
Engine: 355 TPI AFR heads superram
Transmission: tremec TKO500
Axle/Gears: Auburn 3.27 9 bolt posi
i have 2 cars with 9 bolts and as far as iknow the only difference are the axle seals not by year but there is a right and a left just did them a month ago. the axles (in disc rears) all interchange 2.77 or 3.27.
Car: 1987 gta
Engine: 5.0L Aka 305
Transmission: Borgwarner 5 speed
Axle/Gears: 9 bolt 3.45
hey how r you? hopefully everything is good. this is in response to the axle shaft for the 9 bolt diff. if available i want to purchase from you, the left, drivers side axle shaft. mine is bent (long story). it be greatly appreciated, thanks.
Car: 84 Z28
Engine: L69HO
Axle/Gears: 3:73
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Bringing this back from the dead some but i owned a 3.27 posi 9 bolt drum rear. Never got around to installing it and sold it to another fellow board member.
UltRoadWarrior9
Sep 2, 2015 08:24 PM
