Torque arm nuts
Old May 3, 2007 | 09:45 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Torque arm nuts
Lost one of the nuts, where the very long bolts connect to the transmission. I tried the nut from the tranny mount, it fits, but I still need one more *L*, so what size are they ? Metric size or 3/8 fine grade ?
Also, when I remove my driveshaft, I didn't mark it at all, is there a trick as to how it goes, or as long as it's straight and looks aligned, and fits, it's ok ??
It's these tiny hardware problems that are haunting me *L*, couldn't use the GMBB C-clips on the u-joints, had to reuse my old ones, or the u-joints would barely move.
Old May 3, 2007 | 10:25 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Re: Torque arm nuts
Usually it is a good idea to mark the DS, but if not just stick it in straight and snug the bolts uniformly, then give it a good 1/4" turn. I would recommend torquing them. Over tightening them will make it vibrate. If it vibrates, turn the ds 180* out from the rear end.
As for the Torque arm nut, send me your address in PM I will mail you one.
Edit* Nm I thought you were refering to the big friggan nuts for the rear of the torque arm.
Old May 4, 2007 | 12:49 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Re: Torque arm nuts
Yeah I'm talking about the torque arm bolts, the ones that go up front. It seems like they're the same size nuts as for the tranny mount, and I suspect they're also the same size needed for the exhaust manifold to Y-pipe connection as well.
And yes, I can't find them, so I'm missing hmmm 3 bolts.
Old May 4, 2007 | 02:30 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Torque arm nuts
I think they're M8 coarse. They take a 15mm wrench right? If the bolts don't have the SAE markings, then they're metric eh? Try to get the all metal locking nuts.
Old May 4, 2007 | 04:26 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Re: Torque arm nuts
The all metal locking ones ? Not those with the teflon inside ?
Old May 5, 2007 | 12:00 AM
Sonix's Avatar
Car: 1982 Trans-Am
Re: Torque arm nuts
That's nylon, and yea, not those. (those are nylocks).
You want "stovers". All metal, or crimped metal locking nuts. Those suckers don't back off.
Old May 5, 2007 | 12:25 AM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Re: Torque arm nuts
ok kewl, you wouldn.t by any chance know what size nuts that go on the studs on the stock exhaust manifolds, connecting to the stock y-pipe ?
Old May 5, 2007 | 11:33 AM
Sonix's Avatar
Car: 1982 Trans-Am
Re: Torque arm nuts
I think 3/8"-16
Old May 5, 2007 | 12:26 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Re: Torque arm nuts
That's what I thought too, but it looks like they're either worn out, or they actually take metric ones as well
Nervous2
Oct 8, 2015 10:53 PM
luvofjah
Sep 26, 2015 08:28 PM
89newfun
Sep 16, 2015 09:28 AM
Ragtop Man
Sep 12, 2015 12:23 AM
