700R4 OUTPUT SHAFT SWAP
Old May 4, 2007 | 11:04 AM
mopfried's Avatar
Is this hard to do? Does the whole trans need taken apart? I have a 4x4 truck and want to put a car tranny in it.
Old May 4, 2007 | 11:24 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
Re: 700R4 OUTPUT SHAFT SWAP
You must disassemble almost the entire trans.
1) remove pan, lock up converter and filter
2) remove tailhousing and governor
3) Remove servo
4)Remove pump with proper puller
5) Remove reverse input drum and input drum as a unit, carefully wiggling it past the band
6) Remove forward planetary sun gear
7) Remove snap ring for output shaft and remove shaft.
8) Reverse for install
Old May 4, 2007 | 11:34 AM
mopfried's Avatar
Thanks for the quick reply! Now I need to figure out if its easier to do that or rebuild my truck tranny. I can get a reciently rebuillt car 700r4 for $150....
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Reddeath210
Oct 6, 2015 08:20 AM
theshackle
Aug 22, 2015 06:52 PM
formula_novice
Aug 18, 2015 08:48 PM
