speedo challenged
Old May 5, 2007 | 03:56 PM
C6matt's Avatar
Car: 05 C6, 91 z28 Vert, 66 Mustang vert
Engine: Ls2, TPI 350, 289 4bbl
Transmission: T-56, T-5, C4
Axle/Gears: 3.42,3.08,3.73
speedo challenged
I put a new t5 in my car and it had a mech speedo putput, I pulled out the bullet and it had a purple driven gear (22 tooth), and a purple drive gear (7 tooth?). this trans is not original, I just was wondering if other size driven gears with work with my 7 tooth drive gear (what a search told me a purple drive gear is) what driven gear I need for the speedo to read correctly ( 3.08 rear with stock 245/50/16's )
Old May 6, 2007 | 07:09 AM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
Re: speedo challenged
yes, i have the same problem with my t-5...i have a purple output shaft gear ( is that the drive gear? ), but a red gear in the side housing with 3.73 rear...and it's reading too fast...reads 70 when it should be 60...about...any help?
GTAman
Jul 3, 2024 07:29 PM
Elephantismo
Feb 13, 2019 12:51 AM
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
TrevinE
Sep 14, 2015 03:20 PM
