Mega Shifter Problem
Car: 89 RS, 92 Z28
Engine: 305 TBI, 350 TPI
Transmission: 700R4 Both Cars
Axle/Gears: 3.23 Posi.. 4 wheel disc both cars
I have installed my B and M Shifter, and can either get park, and no 1st gear, or first gear, and no park......Have tried adjusting it several times......It looks easy....Any ideas guys....Sure would like to be able to shift into low gear.........What could I have done wrong?????...Thanks, Tom
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: Mega Shifter Problem
i did the mega shifter a long time ago, u have to set the shifter up for a 4 speed auto when its outa the car, follow the instructions they tell u how to set the shifter from a 3 speed to a 4 speed. comes set up for a 3 speed sounds like thats ur prob.
Car: 89 RS, 92 Z28
Yeah you have to remove a metal pin...I did do that....I have read the directions so many times, im lost......Thanks tho, Tom
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
may be an unrelated prob, but the send like a 5ft cable which is way to f*in long, better off buying a shorter 3ft so you dont have to loop it, other than that i dont know
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Transmission: 200C 3 Speed
Axle/Gears: 2.93 Open Diff
Dads having EXACT same trouble! Did you ever fix it? He can get park, but then no 1st, if he sets it up in first, gets no park!
Gallileo60 What fixxed it?!
Car: '89 FB TA GTA
Engine: ZZ4 tpi
Transmission: 3.27 auto: stock gear box
Axle/Gears: Stock
With regards to using a shorter cable:
We had a problem a few years back where the cable melted and broke. It was put in to a garage who "repaired" the cable making it shorter and routing it differntly. We lost 2 gears after this repair job.
JAmes.
JAmes.
Car: 92 Rs
Engine: 4 Bolt "010" 383
Transmission: 700R4 trans brake Hughes 3K convert
Axle/Gears: BW 9Bolt 3.70's
the original cable will work but its not as strong.
what i found works best for me is setting it up in neutral.....
LUKE
LUKE
colton_carlson
Mar 8, 2019 12:21 PM
