Transgo woes
Old May 18, 2007 | 11:08 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
Transgo woes
For the past 2 days i've been in the process of installing this transgo kit into my type 1 '86 700R4.
I got it all back together today and gave it a wirl, but the boost valve seemd to be stuck... So from the threads i've read i took the snap ring out and shot the PR valve, int. valve and boost valve into the pan.
I guess ill try and polish out the gouge's in the valves and give her a go again.
My question is, with the pr, inv, and boost valves out should the trans be able to shift into another gear besides reverse? Currently it will only shift into reverse and I dont want to force it any further.
Maybe I screwed something else up in the process?
Old May 19, 2007 | 09:03 AM
mopfried's Avatar
Re: Transgo woes
I did the B&M kit in my 88 truck. I didnt get the pressure regulator valve snap ring seated into its groove, it was in the counterbore. It didnt come out, but was down lower. I lost 3rd gear..... after driving less that 5 miles.
Old May 19, 2007 | 11:36 AM
Z69's Avatar
Z69
Re: Transgo woes
With the valves out you'll have zero pressure to the clutches.
I did the counter bore thing too. But mine came out while I was doing pressure checks in the driveway.
Old May 19, 2007 | 05:43 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: Transgo woes
don't try to run hte tranny with those valves out!!!!
Old May 19, 2007 | 08:12 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Re: Transgo woes
I only ran it to shoot em into the pan when they were stuck. I got em re-situated, and I had the manual valve hooked up ***-backwards. It will snap your neck on the one to two shift but going from two - three its a little loose. The TV cable opened up the plunger all the way when its floored. Is there any way to firm up the 2-3 a little more?
italiano67
Sep 22, 2015 08:42 AM
crazynights
Aug 21, 2015 06:53 AM
ONEFORMULAOVERALL
Dec 18, 2001 03:13 PM
curt86iroc
Carburetors
Dec 12, 2001 08:58 AM
chris83z28
Carburetors
Feb 12, 2001 09:12 PM
