Tranny Cooling Lines
Old May 19, 2007 | 12:39 PM
dark_daku89's Avatar
Car: 1992 Camaro RS
Engine: 355 Carbed
Transmission: Th350
Hey,
Just have a quick question about the tranmission lines running to the radiator. I just replaced my radiator and I am going to add an auxillary cooler, my question is which tranny line runs to the radiator and which line runs out of the radiator?
Chris
Old May 19, 2007 | 01:29 PM
j dezzy's Avatar
Car: 87 TA
Re: Tranny Cooling Lines
hmmm.... never really thought about it....I didn't think it mattered...
Old May 19, 2007 | 01:40 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
i ran both of mine directly to the cooler.
Old May 19, 2007 | 02:01 PM
Car: 1992 Camaro RS
Engine: 355 Carbed
Transmission: Th350
Hmm... I thought the top tranny line goes to the top of the rad and the bottom goes to the bottom of the rad, and as for sending and return does it really matter?
Old May 19, 2007 | 03:02 PM
j dezzy's Avatar
Car: 87 TA
That's how they're set up. top to the tp of the rad adn bottom to the bottom of the rad...but I don't think there is a certain one for send and return.
Old May 19, 2007 | 05:40 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
yes, if you are installing an aftermarket cooler with the factory onr, you need to have the proper line going to each.you want to make sure the fluid goes to the factory cooler before it goes to the aftermarket one. it will work much better this way.
Old May 19, 2007 | 05:49 PM
Car: 1992 Camaro RS
Engine: 355 Carbed
Transmission: Th350
k, so i guess i could do it like this,
Top line to the rad,
The bottom fitting on the rad will have a hose going straight to the cooler, and then back to the tranny using the stock bottom line.
Old May 19, 2007 | 05:51 PM
87zjeff's Avatar
bottom line of tranny to bottom of radiator-top of radiator to aftermarket cooler-aftermarket cooler to top tranny line.
Old May 19, 2007 | 06:02 PM
Car: 1992 Camaro RS
Engine: 355 Carbed
Transmission: Th350
Thanks very much, thats what I needed to know!!
Hotrodboba400
Dec 10, 2019 07:07 PM
64goatman
Sep 9, 2015 01:09 PM
Stryker412
Sep 7, 2015 09:11 AM
IROCZ1989
Sep 4, 2015 11:54 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
