leaking tranny fluid
Old May 21, 2007 | 09:08 PM
klez's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L Ported SLP Runners and Intake
Transmission: 700r4 w/ shift kit
well i just recently got a 1988 Trans Am GTA, and i have noticed a bit of a leak, it looks to be coming from the back end of the trans but i haven't been able to get under it yet and really see whats going on. you guys think it will be ok to go ahead and drive it?? the leak isnt bad, just dripping every now and again, probly 1 drip an hour or so, probly not any worse than that.
Old Jun 2, 2007 | 08:40 AM
klez's Avatar
Re: leaking tranny fluid
it appears to be leaking out of the tail housing area, its is slightly damp around the 4 bolts holding it to the tranny, but it is worst around where the speedo sensor is. it seems to leak in between the aluminum piece and the actual part of the tail housing, the cylinder -like part leaking tranny fluid-100_2646.jpg
any ideas?
Old Jun 2, 2007 | 04:31 PM
klez's Avatar
it seems like the seal for the speedo sensor is bad,anyone ever had this problem?
my speedometer doesn't work anyways, guess ill buy a new one.
thanks for the input everybody
Stryker412
Sep 20, 2015 06:59 PM
bubbaz28
Sep 18, 2015 02:09 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
