Loud thump when I get on it
Old May 22, 2007 | 07:15 PM
cdiedrick's Avatar
Car: 89 IROC
the other day I got on the gas on my 89 IROC and I heard a loud thump coming from under the car. It did it again consistently everytime I would floor it from a stop. Naturally I figured it was the torque arm and I would ease up and look at it later. When I finally did, it was the from of the driveshaft part. Yoke? Hitting my floor. What would cause this. Again I checked the torque arm, seems tight, the bushing at the rear of the tranny is there bud did seem squishy, but I didn't think it was all that bad. Does that have to be fairly hard, or is there something else I can check.
Chris Diedrick
Old May 22, 2007 | 07:46 PM
2kflhr's Avatar
Car: '68 396 SS/RS, '02 SS
Re: Loud thump when I rod on it
Sounds like a tranny or motor mount.
Old May 22, 2007 | 07:50 PM
F-Body Demon's Avatar
Tranny Mount. I've had 2 do this to me. Go to Autozone get the Energy suspension tranny mount for like $22, its a poly not rubber (last longer + better). Should be in stock PN-311.8 I believe but dont quote me on it lol. Also its listed under the Performance tranny mount on thier computer if you have a dummy behind the counter.
Old May 22, 2007 | 11:20 PM
ecetim's Avatar
Car: 92 RS B4C - needs lots of work!
Engine: 5.7L L98
Transmission: 700R4?
Tranny mount FTW
http://supplespub.com/cars/project-b...progress-made/
Old May 24, 2007 | 09:32 PM
cdiedrick's Avatar
Car: 89 IROC
Thanks guys, I will start with the tranny mount and go from there. Easier than a motor mount ya know.
Old May 25, 2007 | 02:21 PM
Easy way to tell if its the tranny mount is to put the car on stands, and jack up the tranny end by jacking on the torque arm bracket. Just give her a few pumps and if the tranny mount comes apart into two pieces, you have your problem.
Old May 27, 2007 | 08:12 PM
Robb Knight's Avatar
Car: 1989 Firebird Formula 350 TPI
Engine: 5.7 350 TPI
Sounds like the tranny mount to me. I had it happen to me twice. Once on my 87 TA and the other on my 87F'bird. Its a fairly easy job from what I remember. The second time I had the problem was with the TA and I found one one (poly one mentioned bove y somebody) for 6$. I think it was suppose to be like 30, but for some reason it was marked down. The guy thought it was wrong and called some corporate manager or area manager or something to see if he could sell it to me. I made out good as the guy gave him the ok to sell it for $6.
Old May 28, 2007 | 09:01 PM
cdiedrick's Avatar
Car: 89 IROC
Re: Loud thump when I get on it
Thanks guys I will have time towards the end of the week to check it out. i will let all of you know.
Chris
Old May 28, 2007 | 09:08 PM
186irocz's Avatar
For me it was the drive shaft u joint, had a new driveshaft made with heavy duty ones, also the torq arm rubber was worn. Now it squeels the tires into 2nd and 3rd.
Old May 28, 2007 | 09:12 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
If its not the tranny mount then maybe a u-joint. Ive had bad u-joints make thumping noises as they rock back and forth. I had a u-joint go out on the highway going 55 mph and it was some scary crap. Driveshafts have a pretty destructive force when your moving. It bent my output shaft and snapped the the tailhousing and destroyed my exhaust.
86White_T/A305
Mar 6, 2016 01:48 PM
mud runner
Nov 2, 2015 07:30 PM
loud91rs
Oct 5, 2015 10:05 PM
luvofjah
Sep 26, 2015 08:28 PM
ynk1121
Sep 12, 2015 12:27 AM
