De-compping a 700r4
Old May 24, 2007 | 06:33 PM
Cold Dark Shado's Avatar
Car: '86 TA wrapped in '84 skin
Engine: 305 carbed
Axle/Gears: unknown
De-compping a 700r4
I want to get rid of all the comp contolled stuff in my 84 TA, tranny included
What do i need to do to remove the comp controlled stuff from the 700R4?
What electric stuff needs to be removed and what mech. stuff needs to be added to the tranny?
Actually i want to ditch the electrics all together frpom the tranny and motor. So to completely get rid of the ECU/electrically operated or assited stuff what needs to be done besides the carb, distrib?
its stock '86 305/700r4
Old May 24, 2007 | 06:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: De-compping a 700r4
The only thing that the ECM controls in the 700R4 is the TCC. There are at least a dozen ways of handling it without the ECM.
Old May 24, 2007 | 07:22 PM
Engine: 305 carbed
Axle/Gears: unknown
cool, which would be the easiest/cheapest
Old May 24, 2007 | 07:29 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Using a switch on the ALDL and manually locking and unlocking it.
Old May 24, 2007 | 08:19 PM
Engine: 305 carbed
Axle/Gears: unknown
ok you lost me already lol, im not a tranny guy so youll have to explain a bit more with less abbrevations(sp?)
Old May 24, 2007 | 09:23 PM
Engine: 305 carbed
Axle/Gears: unknown
actually i want to ditch the electrics all together
Sorry should have been more clear
Old May 24, 2007 | 11:52 PM
sp63
Guest
Posts: n/a
there are no electronics basically.... its all hydrualic and mechanical linkages... based on how far your foot is in the gas pedal determines most of how your trans behaves..
the torque converter lockup is what saves you gas at moderate speeds... like 40mph and up, cruising. you odnt want to get rid of it.... there is no gain, only a big loss in fuel econ.
Old May 24, 2007 | 11:57 PM
Engine: 305 carbed
Axle/Gears: unknown
You say basically no electrics, so whats there that is? And how to i get rid of it and/or replace it with non electric stuff. i know there is i just dont know how and what.
also swapping to a mech. speedo, got everything for that except the cable
Also doing the same with the motor stuff, I want to get rid of the comp/electric stuff completely
I know i need a diff. carb and distrib, not sure what else if anything tho
Old May 25, 2007 | 12:06 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
do you have electric fans? ECM controls them..
Old May 25, 2007 | 12:08 AM
Engine: 305 carbed
Axle/Gears: unknown
Nope, only things i know i have that are comp contriolled or assited is the carb, ignition, tranny and gauges
Old May 25, 2007 | 12:15 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The computer has nothing to do with the operation of the gauges.
Old May 25, 2007 | 01:07 AM
Engine: 305 carbed
Axle/Gears: unknown
Sweet, i wasnt sure so i thru them in there
So to completely get rid of the ECU/e;ectrically operated or assited stuff what needs to be done? Anything else that i didntmention above?
what electric stuff needs to be removed and what mech. stuff needs to be added to the tranny?
Old Jun 6, 2007 | 12:47 PM
Engine: 305 carbed
Axle/Gears: unknown
bump
Old Jun 6, 2007 | 10:57 PM
kyle folds's Avatar
Car: 89 Firebird
Engine: 355
Transmission: 700
For some reason I am thinking that the TCC was on a vacuum switch in 84.
Check for a piece on the left center firewall ( I think) that has a vacuum hose and a 2 wire connector.
Old Jun 6, 2007 | 11:00 PM
Engine: 305 carbed
Axle/Gears: unknown
My cars only an 84 shell wise, everything (minus the front end which is WS6) is 86 drivetrain, 100% electrical, interior, complete rearend, ect
I want to delete the ECM completely but not sure what i all need to do.
Old Jun 6, 2007 | 11:47 PM
kyle folds's Avatar
Car: 89 Firebird
Engine: 355
Transmission: 700
After more thought, I am now thinking that was on the 82 US cars and thru 85 on cars outside the US.
If your tranny has a 4th gear pressure switch inside it can be wired so that lockup occurs in 4th only
Old Jun 7, 2007 | 09:18 AM
Shagwell's Avatar
Car: projects.......
The transmission is completely mechanical except for the torque converter lock-up. This is controlled by an electrically actuated solenoid valve which controls a hydrualic pressure with the trans to engauge the converter clutch. When eliminating the ecu, you must either run a manual switch to control this function or install a control device(such as a vaccum switch). There is no mechanical way to do this. Nothing that can be changed to mechanical devices, etc. If you do not lock up the converter when cruising in OD, you will eventually burn up the trans, as 80% of the normal cooler flow is bypassed when in OD to allow enough internal pressure to lessen converter slippage and to enable enough perssure for the lock-up function.
There is no way around it.
Old Jun 7, 2007 | 11:50 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There is on 700R4s before 1987.
Old Jun 7, 2007 | 12:27 PM
Engine: 305 carbed
Axle/Gears: unknown
what would i need to convert it to Vac?
Aperiron, you say there is a mech. way on 700Rs before 87, i got an 86. Can you expain more?
Old Jun 7, 2007 | 12:50 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
In valve bodies up to 1986, there was a lock-up valve that would determine a the minimum lock-up speed for the TCC. When used with a check ball in the nose of the solenoid, the valve would always lock the TCC above the minimum speed. Valve bodies until 89 have the bore for the valve, but a non-functional aluminum plug is used in it instead. Valve bodies in 90 and up don't have the bore.
Even if you were still going to use this method, it would be preferrable to still provide some electric control to unlock the TCC with a vacuum switch during heavy acceleration and coasting. This is how the factory did it on non-computer applications.
Old Jun 7, 2007 | 01:29 PM
Engine: 305 carbed
Axle/Gears: unknown
So it would probably be better just to leave it alone til something actually screws up with it lol
To loose the ECM for the engine would i just have to swap out the carb and distrib.?
Old Jun 7, 2007 | 01:49 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Pretty much. Fan control would be a good idea if you have an electric fan.
Old Jun 7, 2007 | 02:19 PM
Engine: 305 carbed
Axle/Gears: unknown
I gotta clutch fan but want to swap to electrics.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
