GearZ
Old May 25, 2007 | 12:20 AM
C.M.Jones's Avatar
Car: 84 Camaro, 90Firebird, 87Transmaro
Engine: custom 5.7, 5.0 , 6.5 Turbo diesel
Transmission: 4spd, auto, auto
Axle/Gears: 2.77 posi
GearZ
you seen that show? it's awesome.
But really Which is better, 3.23 (posi) or 3.42 (one legger) for quick acceleration
Old May 26, 2007 | 07:52 PM
C.M.Jones's Avatar
Re: GearZ
bump
Old May 26, 2007 | 09:14 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: GearZ
power output could be a variable, but the posi should hook better, the pegleg will just spin.
Old May 27, 2007 | 05:25 PM
C.M.Jones's Avatar
Re: GearZ
it doesn't have a problem hooking up I just want the quickest take off possible it has a 350 with a 700R4/with a shift kit
Old May 28, 2007 | 01:19 AM
EvilCartman's Avatar
Car: '82 Z28
Re: GearZ
Put them together, 3.42 with a posi. I had been waiting for GearZ to come on TV for a long time and it's good to see Stacey David back on air
Old May 28, 2007 | 12:43 PM
C.M.Jones's Avatar
Re: GearZ
I would love to do that. Is that plausible? how would I go about doing that? can I use my gears in the onelegger in the posi?
Old May 29, 2007 | 12:28 AM
Car: '82 Z28
Re: GearZ
If it's the same series carrier you should be able to do it. Just swap the 3.42 ring gear onto the posi carrier and change out the pinion gear. You'd also have to re-setup the gears for the proper pinion depth/backlash/gear pattern, all that fun stuff.
Old May 29, 2007 | 12:52 AM
C.M.Jones's Avatar
Re: GearZ
I don't know about all that. is it that comlex, should I take it to a shop?
Old May 29, 2007 | 09:30 AM
Car: '82 Z28
Re: GearZ
If it were me, yes. Changing the parts over is easy but time consuming but if you don't have the right tools to set up the gears, they wont last long.
Old May 31, 2007 | 09:40 PM
C.M.Jones's Avatar
Re: GearZ
Just realized somethin my one legger is a 10 bolt and the posi is a 9 bolt
what do I do
Old Jun 1, 2007 | 12:00 AM
Car: '82 Z28
Re: GearZ
ruh roh ummmm run the 9 bolt I guess... better than running a one legger.
Old Jun 1, 2007 | 01:56 AM
C.M.Jones's Avatar
Re: GearZ
how Do I know if its a 9 bolt "borg warner"?
Old Jun 2, 2007 | 10:36 PM
C.M.Jones's Avatar
Re: GearZ
are my questions that uninteresting?
Stonehenge
Oct 14, 2011 11:52 AM
CommieTerrorist
Dec 10, 2010 11:35 AM
lbarile1991
Dec 7, 2009 09:19 AM
