Ground friendly sealant
Old Jun 9, 2007 | 07:42 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
No matter how tight I tighten up my trans temp sensor it will not stop leaking. Since I need my sensor to be grounded can I use Teflon sealant on the threads and still retain a good enough ground?
Old Jun 10, 2007 | 09:04 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: Ground friendly sealant
Apparently sealant with Teflon it is does not affect the ground. I used this and am having no grounding issues.
Old Jun 10, 2007 | 01:28 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the teflon will kind of wear away when you thread it together so you will still get a good connection through the threads
Old Jun 11, 2007 | 07:19 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
And you'd think an NPT fitting wouldn't leak.
The more I tightened it, the more it leaked.
Old Jun 11, 2007 | 08:15 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Are you using compression fittings ?
Old Jun 11, 2007 | 08:23 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Double flared for the lines into my distribution block and NPT on the D block for the sensor.
Old Jun 11, 2007 | 08:41 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
thats weird that its ot sealing. I dont know what kind of sensors your using but my autometer sensors ground themselves.
Old Jun 11, 2007 | 09:10 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Nordskog gauge and sensor. The sensor grounds itself as well. I thought it was weird as well. Oh well. So far it hasn't leaked and it appears as if the ground is still intact.
Old Jun 11, 2007 | 05:53 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
if all else fails use pipe dope, teflen tape is crap
Old Jun 12, 2007 | 08:04 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I used teflon sealant not tape. The tape IS crap.
billybob6110
Sep 23, 2015 01:30 PM
gta892000
Sep 16, 2015 12:37 AM
sandman92084
Sep 12, 2015 10:27 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
Glowsock
Sep 5, 2015 07:48 PM
