Swapping in 4th gen rear - Can I do this?
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I was thinking of swapping in a 4th gen rear into my 89. I need help:
1. Is the new rear wider or narrower that the one I have and by how much.
2. Since the new rear is disc brakes and my old one is drum. do I need anything besides an AFPR?
3. Can I put my old gears (Strange 3:42) and the auburn diff in the 4th gen housing or not?
Need HELP............thanks
Car: 1989 RS convertible
Engine: 305 TBI LO3
Transmission: TH-700-R4
Axle/Gears: stock axles 3.73 LSD
Re: Swapping in 4th gen rear - Can I do this?
the 4th gen rear end is 4" wider.
ummm what are you gonna do with an adjustable fuel pressure regulator?
yes you can put your other gears in a 4th gen rear as long as u had a 10 bolt before
Car: 89 IROC
AH..........meant to say brake proportioning valve...
I believe it is a 10 bolt.
Will the driveshaft yolk line up OK? Can I swap in a 4th gen driveshaft (I believe they were alum.) without any mods?
Engine: 305 TBI LO3
oh ok. i really dont know anything about switching the brakes from drums but i guess that will work. yes, the driveshaft will lign up fine and one from a 4th gen will take about 10 lbs off your rotating mass if i remember correctly. it doesn't require any modifications just make sure u get one from an auto if u have an auto and a stick if u have a stick.
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I believe all driveshafts from 82-02 V8 cars are all the same length regardless of the tranny. I took a driveshaft from an 02 t 56 car and put it in my 91 auto.
The prop valve, you need a 91-92 1LE prop valve to convert to rear disks, I got a master cyl from an LS1 car as well.
I'm also pretty sure you can interchange the carriers as long as it's a 28 spline carrier.
Car: 89 IROC
ok really dumb question...............what is a carrier (don't laugh)?
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
84 and up they are all the same length driveshaft
82 and 83 had a 3" longer shaft for the TH200c and such,
such as what my car came with from factory
i thought about a 4th gen rear for my 82 but then id have to get some really crazy backspaced wheels
so im not gonna do that
im just going to get a 3.42 or 3.73 drum rear and put aluminum drums on it and be happy with it
not going to spend more or create more hassle than i need, for a daily driver, already have way more $ into this car than it will probably ever be worth
good luck
good luck
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The carrier is the part that the ring gear bolts to. Typically, it's either an open carrier or some sort of limited slip like a posi. You can swap your ring and pinion directly onto the fourth gens carrier. If you want to swap your 89's carrier into the fourth gen housing, you'll need to find out if you have 28 spline axles or not. The majority of 89's will have 26 spline axles. Late in the production year they were changed to 28 spline and the 1990+ all have 28 spline. There's no way you can use your third gen axles in the fourth gen so if you don't have a 28 spline carrier you either use the one in the fourth gen or buy a new one.
Since the fourth gen diff is about 2" wider on each side, your third gen wheels are going to stick out. You'll need fourth gen rims or aftermarket rims with the proper backspacing.
Car: 89 IROC
Thanks very much guys for the advice................really appreciate it
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
