how do i get my axles out?
Old Jul 14, 2007 | 05:31 PM
redliterunner's Avatar
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
I'm taking my 10 bolt apart to freshen it up. How do I get the axles out so I can remove the carrier for new gears and bearings? I'm not seeing any c-clips. Its a posi with 4 little springs in it.
Thanks.
Old Jul 14, 2007 | 05:40 PM
Engine: tpi 305
Re: how do i get my axles out?
wait. Took another look and found them. also took the cross pin bolt out. Should the cross pin slide out easily. Mines moving, but only with persuasion (hammer).
Old Jul 14, 2007 | 05:41 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
when i took apart a rear in my shop, the cross pin slide out like butter, then we just pushed in on the axles and pulled the c clips of and out the tubes slid :S
Old Jul 14, 2007 | 05:50 PM
Engine: tpi 305
yep, put a little lube on it and it slid right out. Those little c-clips are a joke, I can see why people dont like them. There is a spacer on either side of the posi, like big washers. Do those need to be marked left and right or are they the same. They look the same.
How do I get the bearings off the posi?
Old Jul 14, 2007 | 07:01 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
yeah those are your spacers that set your backlash, as i recall make sure they go in just like they came out
I dont remeber if i had removed the bearings or not, I think they may be pressed on although im not sure, Get someone with a better memory then me lol :P
Old Jul 14, 2007 | 09:23 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
bearings are pressed on.. get a bearing remover tool thing.. it looks like this:
can be used to remove pinion and posi bearings..
6speedIROC
16
Mar 15, 2023 08:33 PM
cheesehomer
Dec 31, 2015 08:48 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
usafirebird
Sep 29, 2015 11:58 PM
rudolphschenker
Sep 4, 2015 02:41 AM
