Alto Reverse Input Drum Saver
Old Jul 24, 2007 | 11:40 PM
fenton06's Avatar
Hey guys, I have a question about part of the kit I got from ProBuilt, specifically the Alto Reverse input drum saver.
the directions included with the kit are below. The part I am confused about are where it states "position the wave spring so that the top of a wave is directly over the bleed hole"
In the illustrations also below, I tried it both ways, and #2 did not leak when pressure tested, but I think that #1 is the correct way to install this wave spring.
If anyone has installed this(I am POSITIVE someone has), how did you do it?
File Type: pdf
Old Jul 26, 2007 | 02:12 AM
fenton06's Avatar
Re: Alto Reverse Input Drum Saver
well, problem solved...called Alto and got the scoop...its supposed to be like number 1...
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
devilschariot
Feb 25, 2016 03:08 AM
cheesehomer
Dec 31, 2015 08:48 AM
92projectcamaro
Dec 8, 2015 12:25 AM
Linson
Oct 1, 2015 09:50 PM
