What flywheel to put between 383 & T-56?
Old Jul 30, 2007 | 09:01 PM
budofbama31313's Avatar
Car: 91Z, 97RS, 99Z, 02Z
Engine: TPI 383 Vortec, 3800, LS1, LS1
Transmission: T56, 700R4, T56, 4L60E
Axle/Gears: 3.73, 3.43, 3.42, ?.??
I've just about got together all the parts to drop my trashed 700r4 and put in my T-56, but my question is what flywheel and clutch setup will work inbetween my one piece rear main seal 383 and my T-56 that is from a 95 so is an lt1 T-56? Will the stock setup work or no? any help would help.
Old Jul 30, 2007 | 09:30 PM
Stevo's Avatar
Car: Pair of 92 Z28s
Re: What flywheel to put between 383 & T-56?
stock setup for a 93-97 LT1 car should work fine.
Old Jul 31, 2007 | 01:20 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
one piece main seal is everything above 86, minus the 3rd gen motors(LSx)
correct me if i'm wrong, i mainly work in the 2 piece seal area..
Old Aug 1, 2007 | 11:05 PM
V8Rumble's Avatar
Car: '89 Trans Am GTA
Engine: WAS 350 - now L92 (alum. 378/6.2L)
Transmission: WAS 700R4, now a built T56
Axle/Gears: 3.27 9-bolt
It might be less "prone to confusion" if you were to say the "Gen III" engines (and Gen IV) - even though you specified LSx, there are probably some people who'd still get confused at the phrase "3rd gen motors"...
Old Aug 1, 2007 | 11:39 PM
Hey thanx for the info but I was more worried about it being a 400 crank. From the research I've done the stock flywheel and clutch will bolt right up and work.
Old Aug 1, 2007 | 11:48 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It will bolt up, but whether it will be balanced or not is an entirely different question.
Old Aug 2, 2007 | 09:23 AM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
i wasnt aware that GM ever produced a 400 with a 1 piece RMS. Didnt they stop offering the 400 in like 84 or 85?
I could be wrong here.....
Old Aug 2, 2007 | 09:41 AM
No, GM never made a 1-pc RMS 400.
MOST BUT NOT ALL aftermarket 383 cranks are made for internally balanced engines. If yours is, then a stock LT1 flywheel will work fine. If not, get a stock one, and take it to the balance shop, and have them "unbalance" it to the stock 400 spec.
You MUST determine FOR ABSOLUTELY CERTAIN what kind of crank YOU have. Whatever worked in somebody else's motor, won't tell you a thing about what will work in yours. Talk to the machine shop that built your motor, or ask the crank mfr, what your crank's balance spec is. Avoid talking about "internal" or "external" balance if possible, because an "internally" balanced 1pc RMS engine has part of its balance weight located on the flywheel. This DOES NOT make "all" 1-pc RMS motors "externally balanced", even though to the naked eye, a person who doesn't know what those terms really mean, will perceive the balance weight (which was on the flywheel flange of a 2-pc RMS crank) as being "external". It is NOT "external" even though it sort of "looks" like it. This causes endless confusion in the hot-rod world.
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
Trickskier
Aug 29, 2015 01:12 PM
sreZ28
Aug 14, 2015 07:48 PM
cRoe4
Aug 7, 2015 08:46 PM
