Whos running a 3500 or higher Stall Torque converter on the street?
Old Aug 26, 2007 | 05:32 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Like the title says, Who is running a 3500 or higher stall on the street?
I have a 10" 2700-3000 unit from jegs. It has a leak in the weld and I am sending it back. They said I could upgrade if I wanted to.
I was thinking of going with there 3500-3800 unit. I am running a TH350 with 3.73 gears and 26" tall tires. The cam is the comp xr282hr cam. The cars race weight is 3375.
It is not a daily driver but does see some street use.
Let me know what you guys are running.
Old Aug 26, 2007 | 07:06 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Re: Whos running a 3500 or higher Stall Torque converter on the street?
I've been running a 10in. Coan converter with a 3500 stall for about 5 years now with no problems. Mine isn't a daily driver but does see quite a bit of street time. I used to drive it even more back a few years ago when my combo was more mild. I would even drive it over an hour on the highway to another track to race occasionally. As long as you have a good trans cooler you should be fine. With the current combo that I have now I need a higher stall, so I'll probably go with something around 4000-4500 next spring.
Old Aug 26, 2007 | 08:14 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I am running an external cooler along with the factory one.
I have it running out of the trans into the bottom of the radiator, out the top and into the bottom of the cooler. Then it returns back to the trans.
I hot lapped it last summer a few times and the trans fluid didnt bubble or foam at all.
From what I have heard, there are quiet a few 4th gens running around with 4000 stall on the street.
Old Aug 27, 2007 | 12:50 AM
EvilCartman's Avatar
Car: '82 Z28
Running a 9.5 inch 4,000 stall on the street zero problems and used to daily drive the car with a 3,000 stall. Never had an issue with heat with the B&M cooler only.
Old Aug 27, 2007 | 07:29 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
How did your guys cars drive in stop and go traffic?
Did you notice much difference?
How about you 60ft times? Did it help?
Old Aug 27, 2007 | 08:23 AM
Car: '82 Z28
Stop and go is really no different, you get used to the rpms going up a little higher and not being really "tight" at the lower rpms like stock. I can still idle around with my foot off of the throttle and idle is set at 850ish RPMs. 60' times did improve even going from a 3000 to a 4000. Think I was mostly in the 1.80's but now am in the 1.60's. Need to start doing some suspension work to get those times down even more.
Old Aug 27, 2007 | 03:06 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
3600 here with no issues really, a typical stall for a ls1 car is 4400-5000 now on some of their cams
Old Aug 27, 2007 | 05:54 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
8" 5000 here weekend duty.
its got a cooler with a fan and runs about 210.... but does the job!
Old Aug 27, 2007 | 06:10 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
My brother is running a 4K stall and a friend of mine is running a 4600 stall, both are daily drivers
Both are H/C LS1's though and get 26+mpg on the highway.
Old Aug 28, 2007 | 11:52 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Looks like I will be going with the 3500-3800 one.
Thanks guys.
Old Sep 6, 2007 | 09:13 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Well guys, I got the converter back from jegs.
I must have not seen the right information because they sent back the same part number. I guess I should have had printed off the return sheet from there website instead of typing a letter. So now its the 2700-3000 unit.
Should I just use it or ship it back and try to upgrade again. Its only $10 to ship it. Now would be the time while the trans is out.
Is it going to be worth it? going from the 2700-3000 unit to the 3500-3800 unit?
Old Sep 6, 2007 | 11:57 AM
jbenge's Avatar
I would send it back and try upgrading again. I think its worth the time and effort unless you are in a hurry to get it back together.
Old Sep 7, 2007 | 07:07 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I sent it back yesterday in its original packaging. Just like jegs sent it. I put my info on the back of the invoice and kept a copy for myself.
I would have been crazy not to wait. It should pick my et's up.
In a way, I guess it was good that the first one had a flaw. I should have picked a higher rated converter in the first place. Plus I didnt loose much money to upgrade. Just the shipping cost twice.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
gwade12
Aug 8, 2015 08:17 AM
