can someone do me a favor
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Can someone measure the distance from the bell housing mount surface of the block to the transmission output shaft splines on a T5 installed?
I need to know exactly the length of an instlaled T5 + bell housing combination to see if I can use it for a project, or if I need to modify my driveshaft.
Thanks!
-- Joe
Thanks!
-- Joe
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Car: 2000 BMW M5
Re: can someone do me a favor
A T5 and 700R4 use the exact same length driveshaft. I just took a T5 out and put a 700R4 in, and they measured exactly the same. Same shaft.
Duckman, what the hell is that second transmission? LOL. Three shifters?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 2000 BMW M5
I hope you are putting aftermarket gears in that T5, at a bare minimum. Your setup through a T5 is going to be brutal on it. The T5 internals are very very tiny and lightweight. I would want a trans blanket in between that thing and my legs, too.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I'll probably use the T5 until I can afford a TKO, or a bulletproof rebuild.
-- Joe
duke_mushroom
Oct 9, 2001 10:54 PM
