Shifter problem.
Old Sep 15, 2007 | 02:10 AM
Elthesh's Avatar
Car: 1991 Pontiac Trans Am
Shifter problem.
Something is loose or broken inside the shifter. It's shifts into gear just fine, and you have to press the button to go from P-R-N down to 1, however, in D through 1 I do NOT have to press the button to push it right up into neutral. N to P still requires the normal button press.
What could the problem be and what should I do to fix it?
Old Sep 15, 2007 | 02:21 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Shifter problem.
You don't have to do anything. That's exactly what it's supposed to do.
Old Sep 15, 2007 | 10:49 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
the pushbutton is a kind of safty switch, so you cant just bump the trans into reverse or park when your flying down the road.
RS Reaper
Oct 17, 2018 07:52 PM
ndndndnd
Sep 28, 2015 08:00 AM
