Speedometer Gear Housing for 700R4
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
I am looking for AC-Delco part numbers for a speedometer gear housing for 700R4. From what I have been able to find there are two different AL housings that can be used. The difference between the two is that the first one is used for 30 to 39T driven gears, while the later is used for 40+ driven gears. Also, are there any external distinguishing differences between the two?
//RF
//RF
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Speedometer Gear Housing for 700R4
I'm unfamiliar with the 700R4. The following link "may" provide some info:
http://www.transmissioncenter.net/sp...n_______va.htm
JamesC
JamesC
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The two housings are marked with the ranges of driven gear they're used with. I can post the P/Ns later.
ambainb
Apr 25, 2016 09:21 PM
