Do I have a Problem with my T5
Old Sep 17, 2007 | 11:19 PM
IROCaholic's Avatar
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
I am just about wrapping up everything on my auto to manual swap, so I am sorry for some of the lame questions I have been asking. I just want to be sure everything is ok before I try to drive this thing.
When I sit in my car and shift through the gears with the car off I am having trouble getting it into each gear. For some reason it easily goes into 2nd and reserve but with the others gears I really have to force it in. Am I worrying about nothing or maybe I didnt line up the trans right when I installed it?
Thanks Guys
Last edited by IROCaholic; Sep 17, 2007 at 11:23 PM. Reason: Elimated one question with search
Old Sep 17, 2007 | 11:27 PM
rjmcgee's Avatar
Re: Do I have a Problem with my T5
Sitting there without it running and forcing it into gear is not good for it. Take it out and drive it, it will prolly shift alot better when you actually have **** turning in there and lining up.
Old Sep 18, 2007 | 01:59 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
If you didnt install the throw out bearing correctly it will act like that. Search on this forum for posts by sofakingdom, he post the right and wrong pics to help you out.
Old Sep 18, 2007 | 08:10 AM
IROCaholic's Avatar
Car: 89 Camaro RS
Thanks guys. I think I am going to go ahead and get it running to see if maybe I am just being paranoid. If it ends up being that the throwout bearing is wrong I will just have to pull it soon.
Old Sep 18, 2007 | 09:18 AM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
My car does that too. It has something to do with where the car is sitting. Like if it wont go in first, and I parked on a hill, if I roll a few inches it will go right in.
Also, remember when you want to back up - 1st then Reverse, or it grinds!
Old Sep 18, 2007 | 11:34 AM
IROCaholic's Avatar
Car: 89 Camaro RS
Interesting! I hope that is normal, because to me it seems like I either didnt install the throwout bearing right or that the splines on the bearing and the trans arent lined up. Thanks for the input.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
