Eliminating clutch master cylinder
Old Sep 23, 2007 | 12:32 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Was walking through pickapart and noticed on some Fords the draw fluid from the brake master cylinder resevoir for the clutch. how hard would it be to make an adapter to do this ... has anyone ever done this to their car?
Old Sep 23, 2007 | 02:36 PM
86camaro383's Avatar
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
Re: Eliminating clutch master cylinder
Thats simple. I would say all you need to do is fine a brake master cylinder resurvior that fits in the bores of the stock master cylinder with a tube that goes to the clutch master.
Old Sep 23, 2007 | 06:15 PM
That wouldn't eliminate the master cylinder; all it would eliminate is the reservoir.
So, why in the world would you want to put that stupid Frod crap on your car, anyway? So that when your CLUTCH hydraulic system goes bad, your BRAKES fail TOO ?? Or, when your BRAKES go bad, they take the CLUTCH with them as well? How is that a good idea?
I'm SO glad I don't drive that other brand of car. Thank you for reminding of WHY.
Old Sep 23, 2007 | 07:21 PM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
actually if they figured out how to make it a one way street, where if your brakes fail, you cant operate the clutch, thats not so bad :P
could save you a trip out of the driveway with no brakes, heh
Old Sep 23, 2007 | 08:55 PM
That makes me feel REAL SECURE.... that way, when (not if) the brakes fail, you can't even use engine braking to slow the car down.
I just knew there's been some reason why I've been moving over for the last several decades whenever one of that brand of car pulls up behind me, like, ever since one of my little brothers owned one and I saw how scary it was built. I don't like them back there close to me, with no obstacles between me and them, for some odd reason or other...
Maybe I'm just being even more stupid than usual, which I admit is a very real possibility; but, I'm just really struggling with this concept of how adding YET ANOTHER single point of failure that can disable TWO critical life-supporting systems of the car with a single thing breaking, is something I'd want to add to my own vehicle. Help me out here, anybody?
Old Sep 23, 2007 | 09:49 PM
Jproz1167's Avatar
how can you loose all your brakes in the event of a failure thats impossible. if the master cyl. for the clutch leaks it drains only one area of the masters resovoir. Or maybe better quality parts is why they can get away with it. Me personally I've never had the clutches hydraulic parts fail ...... but then again I replace them whenever I do my clutch so I dont see why it is a bad idea.
Old Sep 23, 2007 | 11:43 PM
dr1's Avatar
dr1
Engine: 305 TBI
I've had 2 or 3 brake line failures in my short life time, and they've all been in the driveway, so thats why it came to mind :P
not that an additional resevoir combined to the master cylinder resevoir is going to cause brake failure in the event of clutch failure, or vice versa.. as noted above.. unless you managed to destroy the whole master cylinder, which personally ive not seen happen ;0
going out of your way todo this seems pretty pointless, the little plastic resevoir is tiny and not taking up any useable space
Old Sep 24, 2007 | 03:00 AM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Its just frod's unquality is job one scenario they did that to save there money and take yours when there is a problem. welcome to proprietyville(windows OS ring a bell)
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
codeysabatini
Nov 10, 2015 04:07 PM
camaro1185
Oct 26, 2015 06:51 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
