82 TA T-10 to T-5 ?
Old Sep 24, 2007 | 08:48 PM
EndlessSummer85's Avatar
Car: 1982, 2000 Trans Am
Engine: 350 bored .040 over: LS1
Transmission: Borg Warner Super T-10: Tremec T-56
Axle/Gears: 4.10s; 3.42's
82 TA T-10 to T-5 ?
Well since finding an 83' t-5 bellhousing hasn't happened, I was wondering if a 84-92 hyd. bell housing would work, if you did a little grinding. It kinda looks like it should, but not sure. Anyone try this?? Can't find an 83' bellhousing and lakewoods $400 bellhousing is just too much. Still debating if I should throw my t-5 in....
Old Sep 24, 2007 | 09:05 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Re: 82 TA T-10 to T-5 ?
I did ... the hydraulics fit with just a little enlarging of where that rod goes through the firewall and drilling 2 holes to secure the hydraulic master cylinder but you will need 84-92 pedals
when you mount the newer pedal assembly in that gives you the place to drill the 2 holes ... its a easy swap mine had a automatic though but it all fit with no hassles
Old Sep 25, 2007 | 02:58 PM
I was wondering if you could make the hydaulic bellhousing work with the old mech. linkage. I really don't want to have to swap out the pedals and all the other bs.
Old Sep 25, 2007 | 03:11 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
What about using the current BH, and tweaking the shifter? Or is that even worse?
I'm going the opposite direction with my T-10, upgrading to hydraulic clutch with the stock pedals - using a hydraulic throw-out bearing.
Old Sep 25, 2007 | 04:32 PM
then everything would be off including he tranny mount. It's hard to tell from pics, but it looks like the only dif between the two bellhousings mech and hyd for a t-5 is the mound for the slave cyl. I'm wondering if it would work with the mech linkage.
Old Sep 25, 2007 | 05:23 PM
Jproz1167's Avatar
only takes about a hour to convert to hydraulic setup. much nice and easier to use then mechanical but it's your car.
Old Sep 25, 2007 | 06:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i would like to see someone swap out just the pedals in 1 hour, that was the hardest part of my 5 speed swap
Old Sep 25, 2007 | 08:58 PM
Jproz1167's Avatar
I did it
Old Sep 28, 2007 | 09:35 PM
catc's Avatar
Car: 1985 Trans Am
Engine: Chevrolet 355
Transmission: Borg Warner W.C. manual cog
Axle/Gears: B W 9-bolt 3.45 Limited Slip
The hydraulic clutch bellhousing will not work with your mechanical linkage because the pivot ball for the throwout fork is in the wrong location. I know this for a fact as i have a mechanical bellhousing and a hydraulic bellhousing and i laid them side by side before i did my T-5 swap .
Old Sep 30, 2007 | 06:30 PM
catc thanks for the info! Appreciate it.
Old Jan 23, 2008 | 08:12 PM
Ok well I finally found a bellhousing from an 83' with the mech linkage. I know I'm gonna need a driveshaft from a 700r4/t-5 car, but what about the tq arm and tq arm mount, and also what about the speedo gears??? and will the x-member still work???
Old Feb 3, 2008 | 06:14 PM
z28freak84's Avatar
Car: 1985 IROC-Z Silver
Engine: Vortec 5.7L
Transmission: WC-T5
Axle/Gears: 3.23 disc brake 10 bolt
crossmember will work. BUT...your holes on YOUR car are 3 inches farther forward than they need to be. Get an extra x-member and hack off the ends. Then weld plates that extend 3 inches further forward and redrill the holes.
There ARE NOT extra holes in the 82's as is on the newer cars.
PurelyPMD
May 5, 2016 04:57 PM
Zane Story
Oct 8, 2015 12:40 PM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
Formula_88AE
Sep 3, 2015 01:47 PM
