aw crap that can't be good!
Old Sep 24, 2007 | 11:13 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
I heard somthing really bad coming from the underside of my camaro tonight. I was just puting it into drive and as always it lurched froward a bit, that's uasal. Then i drive nice for a bit then go about half throttle and then pop! I hear a noise and even feel it! I drive normal and it seems fine. give it throttle no problem. Later I slow down to a near stop and give it throttle... bang! it does it again! I thought i blew something through the rear pan.
What is this! is my rear end going out? a loose connection? bad u joints? HELP! I don't want my rear to blow out if it does not have to!!
Old Sep 25, 2007 | 12:16 AM
alpine247's Avatar
Car: 1988 IROC-Z
Axle/Gears: 2.77 posi stock
Re: aw crap that can't be good!
check ur transmission mount
Old Sep 25, 2007 | 01:50 AM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
X2. Then go by AutoZone and get a $20 EnergySispension Poly one. The OEM rubber ones didnt last long and the 'replacement' rubber ones are worse yet.
Old Sep 25, 2007 | 11:27 AM
ryan91rs's Avatar
Transmission: 4L60
ya that might be the problem considering it's only from a low speed. poly mount it is! (if that is the problem.
Old Sep 25, 2007 | 07:55 PM
ryan91rs's Avatar
Transmission: 4L60
well i got the rubber one because this auto zone did not have a poly one listed so i'll go back to Youngstown this weekend return the rubber one and get a poly one. my old one was ripped right in two.
Old Sep 25, 2007 | 08:39 PM
Mikz86TA's Avatar
The poly ones (Energy Susp and ProThane) have an interlocking core. So in the event they do break, your driveline wont bow up, pound the tranny tunnel and wear out the u-joints. I just bought a new Poly one. My old one was getting pretty worn, but then again it did last about 9-10 years. I went throug 3 rubber ones in a year after the orig one finally gave up after about 8 years. The GM rubbers do last a decent amount of time, but are still known to break apart. The replacement ones just dont seem to last. And adding more power and/or shift kit just kills it
Old Sep 25, 2007 | 10:20 PM
performabuilt's Avatar
The only issue with the poly mount is I hear alot of complaints about vibration transfer with them
Old Sep 25, 2007 | 11:34 PM
Mikz86TA's Avatar
Seemingly. I never had any notible vibes from it. Maybe with a bigger cam 355 like I have now vs. the old LG4 cam was in the 305 B4. Then again with all the poly bushings on it now, everything tight =)
Old Sep 26, 2007 | 09:31 AM
ryan91rs's Avatar
Transmission: 4L60
well i don't want to replace it again. I'm lazy like that as long as it does not vibrate on the highway, i don't care. I need to return this rubber one though (it's made in India and it keeps trying to sell me long distance )
Thanks for the help!!!
Old Sep 26, 2007 | 12:19 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
I dont notice anything in the way of extra vibration at all from mine.
It's a bunch of racket over nothing if you ask me.
Old Sep 26, 2007 | 01:11 PM
Tampa Hurricane's Avatar
I'm glad that I read this post today. I was going to replace the transmission mount on my Trans Am over the weekend, and am now going to go with the poly one instead of the rubber one.
92camaroJoe
Jul 29, 2023 07:57 PM
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
9192camaro
16
Feb 3, 2019 12:21 AM
MantyZ28
Jan 18, 2016 08:30 AM
92camaroJoe
Aug 13, 2015 06:07 AM
