wats the problem?
Old Sep 26, 2007 | 04:40 PM
ripdanny6262's Avatar
wats the problem?
So i can buy my friends z28 with 48000 on it for 900 dollars with no rust the catch is it wont go in reverse , but it will drive in foward in all gears what could be wrong?
Old Sep 26, 2007 | 04:49 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: wats the problem?
the tranny is messed up. LOL. sorry. My grandpa had this problem on an older chevy and he said it was the "diaphragm". Honestly best bet it to bring it to a GOOD tranny shop to get it looked or bring it to the dealer. They usually charge 40 buck to look at it but they never get it wrong.
Old Sep 26, 2007 | 04:59 PM
Well i just wanted to know if it was shot or could be fixed
Old Sep 26, 2007 | 07:39 PM
TheBigJ's Avatar
Car: 85 Firebird
Engine: SBC 383/88BW
Transmission: Built 700R4
Axle/Gears: Moser 9in/3.55
Hey, does it park? check your cable... had a problem like that, ended up buying a new shift cable
Old Sep 26, 2007 | 08:22 PM
Well im going to look at on sunday he said it dosent go in nuetral or in reverse??
Old Sep 26, 2007 | 09:29 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
I would check to make sure the shift cable is not misadjusted..
Old Sep 26, 2007 | 11:40 PM
performabuilt's Avatar
Check the shifter cable first but if it goes into park and dosent roll but goes forward in all other positions then its likley the forward clutch is seized welded together from heat
Old Sep 27, 2007 | 01:11 AM
TheScaryOne's Avatar
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
It might say 48000, but I'm willing to bet $5 that it's got 148000. And if it's just the shift cable, it's worth $900. If it's more than the shift cable, it's worth $900. Moral? It's worth $900
Old Sep 27, 2007 | 01:30 AM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Funny you are =) X2 on ck cable...if not its a candidate for a rebuild.
Old Sep 27, 2007 | 05:32 AM
ss2001's Avatar
Wish I had friends like that.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
