torque converter problem?
Old Oct 6, 2007 | 08:57 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
heres whats happening, i stop at a light and my car is idleing at 750rpm(should be 500) i put it in park the idle goes to 1500rpm i tap the throttle and the idle goes back to normal. A friend told me it could be a faulty converter. the car idles okay after about 45 min of driving. the iac and tps are clean and adjusted correctly. does anyone have ideas or been through this problem. I have to stand on the brakes at stop lights couse it wants to go. thanks alot
Old Oct 6, 2007 | 12:13 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Re: torque converter problem?
What vehicle is it on?
Old Oct 7, 2007 | 11:31 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
its a 1987 transam 305tpi 700r4.
Old Oct 9, 2007 | 08:38 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Could be the worn bushings in the throttle body/carbon buildup keeping the blades open slightly. I doubt this is a trans problem... If your pushing up against the stall speed of the converter it will try to pull through the brakes.
Old Oct 9, 2007 | 01:54 PM
Shagwell's Avatar
Car: projects.......
could be a lot of things, but it's not a converter issue. The tc can in no way make the engine idle to high, especially when in neutral.
Old Oct 9, 2007 | 06:46 PM
Mikz86TA's Avatar
X2 What year did they have the TPI and ColdStart Injector? IDK but could that be a possibility. Usually its a bad MAF or IAC.
Old Oct 10, 2007 | 07:58 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
thanks alot for the info. Even though i took the throttle body of and cleaned it, its got to be something sticking on the tps cause i shot a little bit of pb blaster where the throttle plate connects to the tps lever and it stopped doing it for a day or so.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
xxx3man`
Sep 23, 2015 10:37 PM
dyeager535
Aug 28, 2015 08:10 AM
gwade12
Aug 8, 2015 08:17 AM
