9 inch third member gear setup
Old Oct 9, 2007 | 02:04 PM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Transmission: 700-R4
Axle/Gears: 4.10
As the title suggests I need some help setting up a 9 inch third member. It's complete right but I'm going to swap the open carrier for a trac-loc unit. I'm wondering what needs to be set up. I've read that the pinion depth should be ok which makes sense as it is not touched when removing the ring gear but what type of adjustment need to be made to ensure proper gear mesh and backlash? Any help would be great especially pictures. Thanks in advance.
Old Oct 9, 2007 | 06:50 PM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 4.10
Re: 9 inch third member gear setup
bump
Old Oct 10, 2007 | 03:58 PM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 4.10
Bump
Old Oct 11, 2007 | 11:14 AM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 4.10
umm..... Bump?
Old Oct 11, 2007 | 06:09 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
The 9 inch uses threaded caps, once you replace the gear onto the new carrier, you`ll need set the back lash, using the left threaded collar tighten it until you get 8-10 thou of back lash. You will need to set up a dial indicator to measure this, marking compound on the gear teeth will show you the contact pattern also. I personally have Scott at driveline solutions do my gear axle work, he is on the eastside by 696 and 94
Old Oct 11, 2007 | 10:40 PM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 4.10
How is the backlash measured? Or I should say, what is backlash? The distance between what and what?
Old Oct 11, 2007 | 11:14 PM
it`s measured with a dial indicator and it is the clearance between the pinion and ring teeth
Old Oct 12, 2007 | 09:00 AM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 4.10
Did some research last night and that's what I came up with. Another question, is there a special tool needed to turn the caps? It looks like something with teeth or pegs that would fit into all or some of the holes on the caps may work but I'd like to do it the right way before I go making a tool.
Old Oct 12, 2007 | 08:19 PM
88bracketT/A's Avatar
Car: 88 Trans-Am
Engine: 406 SBC
Snap-On makes a universal spanner wrench that will work for this:
http://buy1.snapon.com/catalog/item....re&dir=catalog
Also before you disassemble the third member measure the existing backlash and write it down. Mark the ring and pinion gears where they were meshed when you measured. After you reassemble set the backlash to the same as it was with the gears in the same spot. This will keep the gear contact pattern in the same place which is what you want. Make sure when you are measuring the backlash that the pinion gear does not turn at all if you have to strap the housing down with the yoke flat on the bench.
Hope this helps.
Old Oct 12, 2007 | 08:24 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
sounds to me like you need to have someone local show you how to set them up or just bite the bullet and pay a shop to do it.
PS You don't need to bump the thread every 4-6 hours to get an answer.
Old Oct 12, 2007 | 08:33 PM
Car: 88 Trans-Am
Engine: 406 SBC
After my post I found this on youtube, may help you also:
http://www.youtube.com/watch?v=bSCUck4M6W4
Old Oct 15, 2007 | 10:08 AM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 4.10
xpndbl3 - Sorry for the bumps, really wanted to get to the track this weekend.
88 - Ahh yes, spanner wrench! Don't know why I couldn't think of that.
greezemonkey - Thank you for the input. I followed your instuctions and finished the job. Nice wear patternd and no whining.
Slight problem though. Still no posi!! This is a posi carrier for sure this time so I assume the clutches are fried. Any sugestions on how to proceed?
Old Oct 15, 2007 | 10:14 AM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 4.10
88 - Just watched that video. Perfect!!! Again, I didn't even think to look on YouTube.
Old Oct 15, 2007 | 05:45 PM
trac loc`s are rebuildable, i know I have seen the clutches for sale.
Old Oct 16, 2007 | 08:32 AM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 4.10
Yup, I think I'll pick up a clutch set from ebay this week and see what I get. I'll keep the thread updated in case anybody else needs to complete the same task.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
