setting tv cable by using line pressure
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
ok i am wanting to set the tv cable using a gauge connected to the pressure port on the tranny. what should the pressure be in each gear, netrual, and any other settings that are used. i am going to get a gauge with hose so i will be able to do this. last time i took it to the shop and they charged me 200 dollars. so if anyone has a link or anything to tell me how to do this i would be greatfull. thanks for the help. -jon
Re: setting tv cable by using line pressure
That's not how it's done. Sounds like somebody took advantage of you.
http://www.tvmadeez.com/article/index.php
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
X2. Its set ONLY one way. But, it is good to verify the line pressure of the TV action, which can be done with that gague and pulling the TV out to verify the line rise. The link above will explain that. Also having an assistant and verifying the pressures in gear too. Definately do that...but ONLY reset the TV properly.
ok so i tried to "set" it, didn't click any so i spaced it out, i got it so it will ratchet out but now the shifts into gear very hard. almost to the point where it will stall it. would that mean that there is too much pressure? this is all after i swapped from tbi to carb if that makes a difference, using the tbi cable.
Did you get the right linkage piece for the carb?
As you no doubt now know from reading and fully comprehending the article, it is ABSOLUTELY CRITICAL that the cable reach its FULL TRAVEL, from idle to WOT. Most of the time, the linkage that comes on carbs, ISN'T set up for that. It doesn't move the cable NEAR far enough (stud too close to the throttle shaft), such that if you set it by the factory method, it's already 2/3 pulled out at idle.
Meaning, pressure gauges or no, no possible setting will EVER make it work right, if that relationship is not right.
Go get the right little linkage piece thing for your carb. Makes all the difference in the world. The Edelbrock one might even fit it, might save you some trouble finding it if it does.
Engine: 355
Axle/Gears: 3.73 Trutrac
Adjusting the TV cable through the line pressure port IS the correct way to adjust the TV cable. The ASTG manual specifies that and the Min. and Max. PSI's that is required in each position. I adjusted my cable exactly as TVMadeEZ stated. My tranny shifted hard all the way through 3rd. Thinking something is not right with the hard shifting is what led me to do the line pressure port reading to see where it was as far as positioning of the TV Cable. The TV cable was WAYYYYY off ( too far in ). The gauge showed that in park I still had high line pressure. There shouldn't be high line pressure in park. In layman's terms, my transmission was still in gear while it was in park.
1st off you need the correct brackets for the carb setup. This gives you the proper range of starting point and the proper range of travel. If you 'reset' it back in and it didnt ratchet out on its own, then you have the starting point too far forward. Your attempt is to bottom the TV plunger out in the tranny at WOT (wide open throttle). This causes the ratcheting out at WOT. Just pulling it out some will do nothing more than f*ck up the line pressures at idle and such. Thats why your pressure is high in park. You need to start with the proper 'reset' and 'WOT' setting. If it doesnt ratchet out BY ITSELF, then you NEED to address the right problem. Your brackets. What carb and manifold?
Oh BTW Pressures It depends on your tranny model. Do you have the ID off the side? That will help. Here is the overall ranges for right now.
TV@minimum : all at 1000RPM
Rev = 84-148
Lo and 2nd = 163-226
Pk Neu 3rd OD = 65-90
TV@maximun : all at 1000RPM
Rev = 157-323
Lo and 2nd = 183-226
Pk Neu 3rd OD = 123-196
Keep in mind these are overall ranges. Like if you have model xxx they are closer ranges. There are about 10 different ranges pertaining to the exact model.
The ID is on the right rear just above the pan line. Its etched into a flat boss there. Get the whole ID, post it and someone can decose it for ya.
Hope this helps. You really want to do this correctly. Trust me on that =)
Rev = 84-148
Rev = 157-323
i will have to look at the id number when i get time. as for the carb and intake i am using an edelbrock 1406 and an edelbrock performer rpm intake
Edelbrock and Holley make brackets to accomidate. I would get the Edel ones. They are the correct geometry fot that setup. Go from there with the reset procedure
From: North Carolina(but you'll never take the DC out of me!!!)
Car: '91 Formula,'02 Silverado,'15 200s
Engine: L98, LQ4, and 3.6 Pentastar
Transmission: 4L60/4L80E/9HP48
Axle/Gears: 2.73posi/3.73posi/3.73
Rev = 84-148
Rev = 157-323
Rev = 84-148
Rev = 157-323
Engine: 355
He needs to know the model. The model is the big 3-4 inch letters and/or numbers on the side. It will be something like MD or MC casted in to the case on the side on the bell housing. Each model has its own set of pressures.
That's all assuming of couse, that the transmission's internals haven't been changed from however they cam as whatever "model" the case says; that it doesn't have a shift kit, or any other valve body or pump or regulator type modifications; and of course, that the TV cable operates over its FULL RANGE from idle to WOT, like it's supposed to, without which it WILL BE IMPOSSIBLE to ever get it to work right.
And of course, you know what "they" say about "assume"...
Sounds to me like, step 1 is to get the right linkage piece, to establish the correct cable travel; step 2 is to set it the factory way; and then go from there.
My rebuilds almost done. Putting the VBody and that stuff in tomorrow and its pretty much done. But I am cleaning the old undercoating off and redoing under the car. Just seemed like a good time to do so =)
Just get me that model and Ill post up the 'orig' pressures.
I'll put it on the ramps tonight when I get home from work. I'll get the ID # and post it tomorrow or later tonight when I get home.
Ill chack later =)
ok so i looked at my id number, it is MD8, so what would the pressures be for that tranny? thanks for the help!!
Engine: 355
The model number is on the back corner of the pan on the passenger side. The number will look something like 1CJM344C. It will be engraved on a little flat spot. You may need a rag or something to clean it off. Let me know and I will get you the pressures. I have the books in front of me.
X2. Thats the number you need
9192camaro
16
Feb 3, 2019 12:21 AM
