QUICK QUESTION reply plz
Old Nov 1, 2007 | 12:05 AM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
OK, my rear in my 84 camaro has me stumped....its a project car and ive yet to drive it, let alone lay down rubber........when you jack the rear end up and spin the tire......one tire goes forward.....the other backwards......ive been told its limted slip.... so when i launch it will both wheels grab? or just a one wheel peel?
Old Nov 1, 2007 | 04:18 AM
PhoenixAshes's Avatar
Re: QUICK QUESTION reply plz
Just from that, it's honestly hard to tell. Unless you have a spool in the rear, pretty much all rear-ends will do that.
Old Nov 1, 2007 | 08:20 AM
jed5161's Avatar
Car: 88 Trans Am GTA
Engine: 383 Lingenfelter/AFR 670 hp
Transmission: 700r4 3500 stall
Axle/Gears: 3.90 9 inch
spinnin by hand it should spin both if its limited slip. unless the limited slip clutches are wore out then it'll act as an open rear end. if thats the case and it is a limited slip it should still have some amount of resistance to it.
Old Nov 1, 2007 | 08:49 AM
scorchmaster's Avatar
Car: 1984 z28
Engine: BBC
Transmission: TH400
With a limited slip, if you spin one wheel the other wheel will spin the other way, you are correct. When you spin the driveshaft, both will spin in the same direction.
Old Nov 1, 2007 | 06:35 PM
88bracketT/A's Avatar
Car: 88 Trans-Am
Engine: 406 SBC
With a limited slip both tires will turn in the same direction. With the open end rear they will turn in oposite directions. You could also tell if you just jack up one wheel an put trans in N, if you can turn the wheel that is jacked up it's open end.
Old Nov 1, 2007 | 06:55 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
well now is as good a time as any to change the 23 year old diff lube, so why not just pull the cover off and see? so guessing there.
Old Nov 1, 2007 | 07:25 PM
Car: 1984 z28
Engine: BBC
Transmission: TH400
If the transmission is in park and you spin one wheel, the other wheel will spin the OPPOSITE direction. If it's in neutral it will spin in the same.
Old Nov 1, 2007 | 08:46 PM
jed5161's Avatar
any posi/limited slip i ever seen has been both in same direction. I got a locker style rear end in my chevy colorado, it'll spin oposite directions as an OPEN rear diff until 100 rpm difference in tire speed then lock in
Old Nov 1, 2007 | 10:07 PM
Car: 1984 z28
Engine: BBC
Transmission: TH400
If you think about it, it's quite easy to see why they spin in opposite directions if the trans is in park. With the ring and pinion locked together, the only things to move are the spider gears and the clutches. I made a picture to help see why this happens. The arrow in red is the direction you are spinning the wheel with your hand, blue arrows are secondary movement based on this and the green arrow is the ouput. REMEMBER, this is based on the transmission in park so the ring and pinion arent moving. If the transmission isnt in park, it allows the ring and pinion to move freely so the clutches take over and the spider gears dont move freely, they move with the carrier and follow the carriers directions of rotation
Old Nov 2, 2007 | 01:43 AM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
i think the clutches are wore out....you can jack up on the passenger side and spin it.....but its really hard to....like all i can do to make it move
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
