need help on pullin tranny!
Old Nov 7, 2007 | 11:50 AM
86irocguy's Avatar
Car: 1986 Iroc-Z
Engine: 350 4-Bolt Main
Transmission: Rebuilt 700R-4
Axle/Gears: 3:42
ok i just got a new engine in my car and got it running but wheni put tranny fluid in it then it didnt wanna even try to go in gear so i came up with the conclusion that it is the pump. but now when i go to pull the tranny i am having troubles tryin to figure out how to get the tranny lines off.i am workin on jackstands since my shop isnt finished being built yet so i dont have a tranny jack or anything. im having to use a floor jack and i cant let it down but so much before the distributor hits the firewall. can anyone give me a few pointers on how to pull this tranny since this is my first time pulling one out of a camaro? any help would be greatly appreciated.
Old Nov 7, 2007 | 12:19 PM
Whiplash's Avatar
Re: need help on pullin tranny!
If you can not get the transmission down far enough, if it is the distributor cap that is hitting then take it off, if it is the distributor itself then you will have to pull the exaust down, then the lines will be in the open and you can get them off. hope this helps
Old Nov 7, 2007 | 12:36 PM
86irocguy's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3:42
thanks alot for the help. any help is greatly appreciated.
Old Nov 7, 2007 | 12:40 PM
Whiplash's Avatar
Glad I could help.
Old Nov 7, 2007 | 12:50 PM
You DID put the torque converter bolts in; right?
Old Nov 7, 2007 | 03:12 PM
86irocguy's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3:42
yea everything was put back togather like it should be. we put the tranny back on the engine while it was out of the car so we put the torque converter on the tranny and put it up on the engine but when we was bolting it down it popped twice on us so i think i may have broke something in the pump.
Old Nov 7, 2007 | 03:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
How much space was there between the torque converter and the flexplate when you bolted the bellhousing up, before you bolted the torque converter.
Old Nov 7, 2007 | 03:24 PM
86irocguy's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3:42
to be honest im not really sure as i didnt bolt the torque converter up after the tranny was bolted up. my best friend who i work with done it.
Old Nov 7, 2007 | 03:43 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I'm guessing there wasn't any space because the converter wasn't seated correctly, and now you've killed the pump.
Old Nov 7, 2007 | 03:49 PM
86irocguy's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3:42
could be. i did notice one thing. i went from a 305 to a 350 block and the flex plate is bigger on the 350 could that have anything to do with it? the holes still line up and everything. im using the same tq converter that was on the 305.
Old Nov 7, 2007 | 04:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No
Old Nov 7, 2007 | 04:16 PM
86irocguy's Avatar
Car: 1986 Iroc-Z
Axle/Gears: 3:42
ok thanks.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
bjpotter
Oct 4, 2015 07:48 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
