New Transgo Symptoms
Old Nov 11, 2007 | 07:51 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Well, I got the car back and redid the seperator plate correctly. The car now shifts firmly into all gears except the 1-2 transition, which is soft and very slow.
My mechanic says that he could not complete step 1 of the transgo kit (boost valve,etc). Where are these components located, and could this cause the 1-2 problems.
Old Nov 11, 2007 | 08:15 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
Re: New Transgo Symptoms
theres no reason why he wouldnt be able to change the boost valve
Old Nov 11, 2007 | 08:35 PM
Toehead's Avatar
I know.
Do you know where the boost valve is located?
The pump cover is accessible with the transmission in the car, correct?
Old Nov 11, 2007 | 10:25 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
yes, it is easily accessible. did he say why he couldn't complete that step?
Old Nov 11, 2007 | 10:32 PM
Toehead's Avatar
He stated that he couldnt find it.
Does anybody have a picture of the pump cover so that I can show him?
Old Nov 11, 2007 | 10:39 PM
87zjeff's Avatar
it is on the opposite side of the filter from the lock-up solenoid at the front of the transmission. you can see the lock-up solenoid in the upper left corner of this pic. the filter goes to the right of it in the dark spot, and the boost valves go to the right of it in their own bore. unfortunately this pic isn't a very good one because they used a reaaly bright flash and you can't see the bore real good.
Last edited by 87zjeff; Nov 11, 2007 at 10:43 PM. Reason: addition of information.
Old Nov 11, 2007 | 10:58 PM
Toehead's Avatar
Cool! Thanks.
I found this site: http://www.camarobay.com/Transgo.htm
What effect would not doing the first step have on the kit?
The 1-2 shift is very very slow.
Old Nov 11, 2007 | 11:39 PM
Toehead's Avatar
I hate to be a PITA but do you mind circling the bore, just so I can point EXACTLY to where the valve goes! Thanks
Old Apr 25, 2008 | 07:05 PM
Toehead's Avatar
Back from the dead.
The car is out of hibernation, and I really need to get this fixed. Everything is great except the 1-2 transition. I have the new boost valve.
Could the boost valve be causing this problem?
If not, any pointers?
I'm most likely going to do this myself, most likely tomorrow.
db057
Jan 10, 2020 08:55 PM
Elephantismo
Feb 13, 2019 12:51 AM
Grant2k
Apr 4, 2016 08:21 AM
racereese
Oct 3, 2015 03:46 PM
italiano67
Sep 22, 2015 08:42 AM
