Will an M5 Tranny hold up to a 350 TPI?
Old Dec 1, 2007 | 11:25 AM
Gregg85IROC's Avatar
Car: 1985 Camaro IROC-Z
Engine: 5.0L 305 V8
I'm looking to swap in a 350 TPI into my 85 IROC, but I'm wondering if the transmission will hold.
Old Dec 1, 2007 | 02:43 PM
gary sanders's Avatar
Car: 89 trans am GTA,90 model trans am 350 tuneport,87 firebird
Engine: 355 small block
Transmission: 5 speed,auto 700r4
Re: Will an M5 Tranny hold up to a 350 TPI?
Should be just fine,Ive run 450 horse motors with a stock T5,wont hold up long,if you abuse it ,but if you shift like you got a little sense,then youl be alright.Just bolt your bellhousing,flywheel and use your starter off the 305 on the 350,and it should work great for ya!!! You did mean T5,?
Old Dec 2, 2007 | 12:28 PM
Engine: 5.0L 305 V8
haha yeah i did mean T5
thanks for the help
Old Dec 2, 2007 | 12:33 PM
jimmy92rs's Avatar
Car: 1992 RS
Engine: 01' LS1
Axle/Gears: 10 bolt auburn pro posi, 4.10 gears
i have a t-5 behind my 355 engine and its holding fine for now. but ever since i started hitting it with nos, its strarting make noise. as long as u dont gring gears it should hold up fine. if ur engine is stock i dont think youll have a problem. if u are going to get a t-5, get a world class version, they are stronger.
Old Dec 2, 2007 | 12:39 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
https://www.thirdgen.org/forums/tran...tpi-issue.html
Old Dec 2, 2007 | 12:41 PM
Engine: 5.0L 305 V8
Thanks Kevin, you can probably close this thread
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
