strong vibration
Old Dec 13, 2007 | 09:58 AM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
strong vibration
I'm trying to pinpoint my problem before spending money and time. I have a severe vibration that goes though the entire cabin at 72 mph and on in fifth gear at 2200 rpm.
If I take it out of gear the vibration goes away.
If I take go to the same speed in 4th gear, it is silky smooth.
At the same rpm in 4th, I don't have a strong vibration (maybe very slight but that could have been the road).
These symptoms have me believe that it may be fifth gear related; however, I am not exactly sure.
Old Dec 13, 2007 | 11:22 AM
lonman89's Avatar
Car: 1985 chevy camaro IROC-Z
Engine: 5.7 litre 350 4 bolt main
Transmission: 700r w/B&M shift kit
Axle/Gears: 10 bolt w/3:42 gears
Re: strong vibration
id check your tranny mount also,it may be wearing out and could be causing the vibrations
Old Dec 13, 2007 | 05:51 PM
funkdubie's Avatar
Car: 85 z28
Engine: 355ci
Transmission: th400
u joint or slop in the output shaft is what i'd check..
Old Dec 18, 2007 | 10:08 PM
Car: 91 Camaro RS
Haven't drove the car in two weeks so I haven't had a chance to try anything yet.
If it was a transmission mount wouldn't the vibration be the same in any gear at that speed.
I'll have to get under there and look for potential causes of vibration.
Old Dec 18, 2007 | 10:50 PM
lonman89's Avatar
thats what i thought,id drive for awhile and it would be fine but when id decelerate id get alot of vibration and i thought it might of been the shift kit but sure enough it was the tranny mount,also broke 2 shifter cables in the process,not sure its thats the case with yours since its a manual tranny
Old Dec 26, 2007 | 06:21 PM
funkdubie's Avatar
Car: 85 z28
Engine: 355ci
Transmission: th400
any luck yet?
Old Dec 26, 2007 | 09:52 PM
Car: 91 Camaro RS
We keep having winter weather whenever I could be driving it. And on the rare nice day I am working. So its almost been a month since I've driven her.
Anyone know if 5th gear has its own bearings that tend to wear out?
Old Dec 26, 2007 | 10:49 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
My car has that same vibration. It happens in fifth gear, and is barely there at 70mph. It gets very noticible at about 73mph, and annoying at 75. By 85mph, the car feels like it is going to shake apart. Also, the vibration gets faster as the speed goes up.
I thought origionally that it was out of balance tires. But the weights look brand new leading me to believe they were just balanced. I never did get a chance to balance them myself tho, I quit my tire job too soon.
Also, I have no idea weather my car does it in another gear or not. I will try this. But any solution would be nice, thanks.
Old Feb 10, 2008 | 09:16 AM
Car: 91 Camaro RS
Well, the other night I started taking the transmission out to replace the clutch. In doing so I found that one of the u joint bolts was lose by 2 revolutions. It didn't seem like the driveshaft had any play from underneath the car. However, at 70+ mph it may have been a different story.
Also what ujoints should I use for my car. I have a 2000 Aluminum Driveshaft with 1986 rear end. The catalog of u-joints have a couple different listings for various years/ driveshafts.
Old Feb 10, 2008 | 09:30 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Humm, did the U of the 2000 shaft fit the pinion yoke of the 86 perfectly? If the LS1 and JG1 shafts have the same U, I'd expect you to have a mating problem with the 86. The P/N and some info are included in the following link:
https://www.thirdgen.org/forums/tran...light=carquest
JamesC
Old Feb 10, 2008 | 10:59 AM
Car: 91 Camaro RS
JamesC
Well, the u-joints seem to fit fine into the yoke. But I've read a couple posts about requiring different u-joints when dealing with separate applications, so it was just to confirm.
RS Reaper
Oct 17, 2018 07:52 PM
69GTOby
Apr 18, 2016 02:34 PM
roysatikas
Sep 22, 2015 08:15 PM
InfinityShade
Sep 18, 2015 08:32 PM
Glowsock
Sep 11, 2015 11:09 PM
