installed the megashifter and now the car bogs down when it shifts
Car: 2000 Trans am vert 87 GTA
Engine: 5.7/5.0
Transmission: T56/700R4
i just got a megashifter out of the junk yard ( all of it minus the switch ). the plug on the tranny had the wires re-routed. one was just cut. one whet to a switch under the steering column ( i believe it was the brakes or something ) . And one that was converted to a ground. now when i put the car in OD it trys to stall when it shifts out of 1st 2nd and 3rd. i have adjusted the cable a billion times. i have a problem with that also but i want to fix the freaking shifting first. also sometimes if im driving slowly and it gets to 3rd the rpm's will drop to about 800, however if i shift it myself it goes decent. i need some help and i need it quick im afraid to drive m car right now
Engine: 5.7/5.0
Re: installed the megashifter and now the car bogs down when it shifts
it shifted fine when the car had the stock shifter. i had no problems
Car: 1985 Z/28
Engine: L98 Carbed
Axle/Gears: 9 Bolt Posi 3.45
If his TC is locked will it do that? maybe those wires has something to do with it.
Engine: 5.7/5.0
it was the TC it wasnt locking up. i swapped out the plug and now it works perfect.
dhonda200
Aug 11, 2015 11:50 PM
