corvette auto into camaro body bracket
Old Dec 22, 2007 | 07:06 PM
sps589's Avatar
I have a design for a bracket to be able to install a corvette automatic trans into a camaro body using th camaro tailshaft housing. If interested leave me a message.
Old Dec 22, 2007 | 07:54 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: corvette auto into camaro body bracket
so other than the length of the output shaft, the tail housing, and the fact that the corvette case doesn't have the mounting holes for the crossmember into a thridgen., what is different about the corvette tranny other than the name corvette? any 700r4 can be built to vette specs with a good rebuild kit.
don't get me wrong, i'm curious to see how you did it. the only way i can think of is to use the tail housing to mount the trans to the crossmember. this would put even more stress on the tail housing that it doesn't need.
Old Jun 16, 2008 | 09:14 PM
tango1112's Avatar
Car: 1982 Firebird
Engine: 355 CID
hi, interested in the design idea... I have a corvette tranny going into a firebird, would like to get an idea of what the bracket would look like, etc... Also, any ideas on the torque arm?
Old Jun 18, 2008 | 07:29 PM
andresinibus's Avatar
Car: 85 Z28 W/T-Tops
Engine: 383 crate engine edel carb n headrs
Transmission: ex700R4/NOW T5
Axle/Gears: 3.08 std
about some pictures here so we all can see it
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
