9 bolt VS 10 bolt rearends
Old Dec 27, 2007 | 07:15 AM
joshh44's Avatar
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
what is a better rearend?
i would like to get a beefer rearend. but that is fairly cheap as well.
i found a 9bolt rearend on the hawks website which dont seem to be to bad.
are they stronger then the 10bolt??
reason i ask is im gunna put in bigger motor. got a new tranny for the extra power of the motor. and my last weakspot would be driveshaft and rearend. ill beef driveshaft last. so im just woundering abut the 9bolts. are they pretty much the same as a 10 bolt? if they fairly the same i might just fork up the extra dollars and get a 12 bolt or a 4th gen rearend.
im jsut trying to find the best way for the cheapest dollar.
any suggestions?
Old Dec 27, 2007 | 07:34 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: 9 bolt VS 10 bolt rearends
The 9-bolt is stonger then the 10-bolt due to the 7 3/4 dia ring gear and different and better internals. Unless you are looking at 400+ hp and want to spend $2500 for a 12-bolt, I would go with the 9-bolt. I swapped in a 89 9-bolt years ago.
Old Dec 27, 2007 | 07:39 AM
joshh44's Avatar
Engine: engineless
oh yeah my engine should be putting im hoping 450-500hp.
are they a direct swap in?
Old Dec 27, 2007 | 07:52 AM
joshh44's Avatar
Engine: engineless
by the way. how do you identify ifits a 9 bolt or 10 bolt? just count the bolts? lol
anyways did they come in the Camaros? im hoping to eather have a direct bolt in or something with minor mods to it.
Old Dec 27, 2007 | 09:11 AM
r62mcmahon's Avatar
Car: 1989 IROC
Axle/Gears: BORG WARNER /3:70
yes the 9 bolts came stock in surtain 3rd gens. you just count the bolts
Old Dec 27, 2007 | 12:00 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i'd go 9" if you think eventually you'll make any more power, sell the rear you have now for any profit you can, think of it as savings toward the 9". Have moser put on GM housing ends, buy some LT1 brakes from a local junkyard or whatever and you'll be set. I got my 9" from bob at exotic performance plus out of indiana. Really great guy to work with and much better prices than any other shop I've seen. he's a sponsor on ls1tech.com
Old Dec 27, 2007 | 02:46 PM
joshh44's Avatar
Engine: engineless
i thought about a 9" rearend. but all the websites i seen for em are around 2 grand for the set up you just said. i dont have that extra cash on me. i was thinking maybe more around 500- 750 bucks. at the most.
how much did it cost you to get someone to build you one?
Old Dec 27, 2007 | 07:33 PM
xpndbl3's Avatar
Car: 1984 Z28
mine has a lot more options than the average person would want, so my amount doesn't really count. The housing and axle package is $1000 from exotic performance off ls1tech.com then you'd need a center section, which I've seen on ebay for $499 or similar completely gone through. new bearings, etc. I popped 4 ten bolts and 1 9 bolt, so I got sick of working under the car for something I should have just bought the first time around. IF you're not running slicks or going to the track, then a ten bolt "should" be fine if you're not beating on it.
Old Dec 27, 2007 | 07:55 PM
joshh44's Avatar
Engine: engineless
ill check the website out thanks
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Numbah-1
Sep 12, 2015 08:57 PM
WickedBowtie
Sep 11, 2015 11:24 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
