olds 403 12.5 in 1/4 92 camaro need little help
Old Jan 10, 2008 | 06:53 AM
89fbrestor's Avatar
Car: currently 91 camaro
Engine: soon to be 350 turbo
Transmission: soon to be 4l80e
Axle/Gears: 99 ss rear end with richmond 4:11's
ok got a new toy, 92 camaro with an olds 403 motor, bored .030, performer intake,stock heads, stock manifolds, holey 750, built 350 turbo trans, 3:73 true posi rear. it ran 12.5 in the quarter and smoked a new cobra in the process i have headers and the rpm intake i'm going to put on in the next couple of weeks. thats the run down on what the car has, my question is with this trans and the rear its no fun for street driving. does anyone know what trans i can bolt to this 403 that would have an overdrive or something that would be more streetable? thanks for any input.
Old Jan 10, 2008 | 07:04 AM
Re: olds 403 12.5 in 1/4 92 camaro need little help
200-4R; or a 700-R4 with an adapter plate.
Old Jan 10, 2008 | 07:15 AM
89fbrestor's Avatar
i did'nt think i could do the 700r4. cool anything special i would have to do? anyone know where i can get the adapter plate. finding parts or just about anything for this motor i'm learning is hard other then mondello's or fcr it's impossible ot really expensive. thanks for the input
Old Jan 10, 2008 | 10:05 AM
All the usual suspects... Summit, Jeg's, your local speed shop, etc.
Putting a Chevrolet transmission (Powerglide specifically, but it's the exact same fitment) behind ANY kind of motor, is THE SINGLE MOST COMMON swap of that sort. There are a half-dozen mfrs of that motor plate that I can think of off the top of my head. You won't have any trouble finding one, believe that.
And not likely to get easier as time goes on.... Just one more of the many reasons why swapping those old "foreign" motors, no matter how "good" one might think they are, into these cars, is not always as wise as some might tell everyone who doesn't have experience with it.
Old Jan 10, 2008 | 12:20 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Well, you know how I feel about it, right!
Nice job!
You want to run an adapter for the 700R4, then you can use a stock torque arm and crossmember. If you already have an aftermarket torque arm (I don't know since you have a TH350) then I actually prefer the 2004R because of the 2.76 first gear, compared to the 3.08 for the 700R4. If you use an adapter, then get a good one from either trans dapt or advance adapters. It will come with a 3/8" thick adapter plate, spacers for the torque converter bolts, and a nice nose bushing for the torque converter to fit against the crank end. The cheaper adapters don't have those and YOU WANT THE TORQUE CONVERTER NOSE BUSHING.
Where are the pictures of the engine? You should post pictures in the engine swap forum so that I can add them to my archive.
Again, good job!
Old Jan 10, 2008 | 09:12 PM
89fbrestor's Avatar
thanks for the info guys, i will contact a trans shop about the adaptor and getting a trans built that will hold up. the 403 has some pretty good torque i can get the front tires about 6inchs off the ground right now i do have some pics but not sure how to load them up on this site. anyone wanna load one up for me? thanks again for the help.
brian
nevermind i see how to load a pic up now i'll put one on in a few minutes
Last edited by 89fbrestor; Jan 10, 2008 at 09:15 PM. Reason: Automerged Doublepost
Old Jan 10, 2008 | 09:26 PM
89fbrestor's Avatar
pic of the car engine
Attached Thumbnails olds 403 12.5 in 1/4 92 camaro need little help-sunp0014-2.jpg   olds 403 12.5 in 1/4 92 camaro need little help-engine.jpg
Old Jan 10, 2008 | 11:30 PM
KrisW's Avatar
Engine: 2.8/TBI/TPI
You want to search pro built automatics on this site or this guy on the east coast:
http://www.ckperformance.com/
Either way, nice job, again!
Old Jan 10, 2008 | 11:55 PM
89fbrestor's Avatar
thanks, love this site
evilstuie
Jan 9, 2020 08:29 PM
colton_carlson
Mar 8, 2019 12:21 PM
TheExaminer
Aug 19, 2015 10:07 PM
matthew911
Aug 12, 2015 09:38 AM
