transgo
Old Jan 15, 2008 | 09:41 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
transgo
i have the transgo shift kit i installed but i would like to know the size,did the
boost valve assembly that came with the kit is it a .471 or a .500 i would like to frim up my shifts a little
Old Jan 16, 2008 | 04:10 AM
gr8apmech's Avatar
Re: transgo
mine came with a .500 but i asked for it...I know PRO BUILT would know the answer to this. Dana should be lurking around here, PM him. I'd like to know myself...like I said, i'm only an amature at this rebuild stuff-I just built my 13th 700R4 last night.
Old Jan 16, 2008 | 08:29 AM
antoine's Avatar
Re: transgo
I built mine but i used the alto reds 3-4 clutch pick,but i found out those
are not good,also jegs has a .570 boost valve $33.99
Old Jan 16, 2008 | 09:30 AM
Pro Built Automatics's Avatar
Re: transgo
If the kit is from TransGo, it will have the .500" main boost valv and the .300" intermediate/reverse boost valve also.
Old Jan 16, 2008 | 09:37 AM
antoine's Avatar
Re: transgo
dana how do you firm up fourth gear?will your kit help.
Old Jan 17, 2008 | 01:48 AM
Re: transgo
The kit Performance Shift kit from TransGo for the 700R4 has the 4th gear modifications for a firmer 4th gear. You can go larger than the stated .155" feed hole for the 4th gear feed hole in the separator plate. I use .187" - .204". TransGo used this size in previous kits a few years ago. I would only do this modification that I suggest with a 10.5" or smaller diameter torque converter.
Old Jan 17, 2008 | 09:41 AM
antoine's Avatar
Re: transgo
I will open the feed hole like you said because i have the continental 10 inch
non lockup converter
italiano67
Sep 22, 2015 08:42 AM
crazynights
Aug 21, 2015 06:53 AM
ONEFORMULAOVERALL
Dec 18, 2001 03:13 PM
curt86iroc
Carburetors
Dec 12, 2001 08:58 AM
Js92RS
Nov 28, 2001 01:28 AM
