taking out axle
Car: 86' Z28
Engine: 5.0l w/ new cam
Transmission: TH-350
Axle/Gears: 4.10's
taking out axle
im having trouble taking out my axle, im under the impression you have to take out that little pin in the middle of the differential, but its almost rounded off. any suggestions on what to do? and are the c-clips those two things on either side of the differential that have the 2 big bolts on them?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: taking out axle
The locking bolt for the crosspin shouldn't be that difficult to get out, it's not a big thing and it's not torqued down very hard. The bolt almost always breaks right above the last thread though, so don't feel too bad if that happens to you.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: taking out axle
Remove the retaining bolt for the center pin. As mentioned above, it's common for it to break but isn't that difficult to remove if it does. With the retaining bolt out, slide the center pin out. When the center pin is out, the axles can be pushed in so that the c-clips fall out. Then the axle can be pulled out.
Engine: 383 Carb
Transmission: 4L60
Re: taking out axle
Just to make sure, you've got a 10 bolt, right? If it's a 9 bolt, you don't have C clips and you can just unbolt the bearing retainers on the axle housing flanges and pull the axles out with a slide hammer.
Car: 86' Z28
Axle/Gears: 4.10's
Re: taking out axle
i got all of that done. now i put it all back together. but how do i get the differential fluid into the differential?
Car: 86' Z28
Axle/Gears: 4.10's
Re: taking out axle
thanks for all the help you guys. i got the axle in and ready to go. i drove it today in the snow, and wow, those corners are a bit tricky for a 15yo.
Hotrodboba400
Dec 10, 2019 07:07 PM
dbrochard
Oct 3, 2015 12:43 PM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
