T5- DOES IT MATTER IF I USE DEXRONIII OR GEAR OIL
Old Jan 22, 2008 | 07:58 PM
tripingeorge3's Avatar
i have know idea what t5 i have. it came out of an 86 z28. it looks like it has tranny fluid in it, but i keep reading that to 86 had gear oil, and auto trans fluid was only recommended for the 88 -up t5 's
Old Jan 22, 2008 | 08:38 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: T5- DOES IT MATTER IF I USE DEXRONIII OR GEAR OIL
My Chilton's manual says 1985-92 uses Dexron automatic trans fluid. It says 82-84 5 speed uses gear oil.
Old Jan 22, 2008 | 08:48 PM
gregriggan's Avatar
Car: 1992 Camaro RS
Engine: LQ4 6.0
Axle/Gears: 4.10
there are really easy ways to check whether or not you have a WC tranny or not. If you do you definitely need to use ATF because of the clutch-type material on the synchros
-Greg
Old Jan 22, 2008 | 09:22 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Crawl under the car and look. There should be a sticker right on the side of the tranny that says "Dexron II"
you arent going to find DII anywhere anymore, but just use some DEX/Merc from walmart for cheep. It's basically just Dexron III (the liscense expired I think to actually call it Dex III now) but its backwards compatible.
Old Jan 22, 2008 | 09:47 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Get some of the fluid on your clothes, walk in the house. If your wife/mom says "ooh, you stink" it's gear lube. Otherwise it's ATF. But I'd bet it's ATF.
Old Jan 23, 2008 | 05:30 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Check FAQ for more info about fluids. Check the sticky at the top of the page for info on identification.
JamesC
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
