Shifter cable
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Shifter cable
Hey Guys,
Im hooking up all my carb and trans linkage. Carb and trans kickdown on the carb are all set now I gotta hoke this up. Which I think is the shifter cable(correct me if im wrong). But I notices the plastic around the cable is worn out and theres about an inch or so of exposed cable. Is this ok or do I need to get a new cable? Also Does it just snap onto the lever on the trans or is there a retaining clip that goes on too? Got a few pics to show what im talking about, thanks.
Worn cable?
Worn cable?
Re: Shifter cable
Could be worn. On mine, the inner cable isnt exposed. It looks like the inner cable stretched out. Why would GM want to have such an important cable exposed like that?
Car: 84 Z/28
Transmission: 700R4 - rebuilt by me
Axle/Gears: 3.73 posi
Re: Shifter cable
You need a new one. With that much cable exposed, the shifter won't actuate the shift linkage until all that slop is taken up, and you don't have the travel at the shifter to compensate for it.
Car: '90 RS
Engine: Vortec 350
Re: Shifter cable
Hum, how long will this take to change out, gotta pull apart the whole center console right?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Shifter cable
It takes about 5 minutes and if you can work by feel, you don't even need to jack the car up.
Car: '90 RS
Engine: Vortec 350
Re: Shifter cable
Ok well I got the car on stands right now so that makes it easier. But when I was lookign a tit tthe cable goes through the bottom of the car so dont I need to disconnect that end from the shifter first?
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: Shifter cable
doesn't matter which you disconnect it from first...disconnect it from the linkage on the tranny, disconnect it (if not already done) from the shifter, slide it out to underneath the car, connect the new one up to the linkage on the tranny, put the other end into the same hole of the car, push the water plug in, go inside the car, connect the shifter linkage to the shifter, and put the cotter pin in and your done.
Car: '90 RS
Engine: Vortec 350
Re: Shifter cable
Ok im gonna revive my old thread instead of making a new on. Wheres the best place to buy one of these cables? I checked hawks and a couple other places and tis about $50. Is that about right or should I just go to the junkyard and get one
TMZIrocZ350
Oct 7, 2015 12:09 PM
