Car won't shift at cruise, when it does, WHAM! Kit and Vette mod 700R4
Old Feb 4, 2008 | 04:22 PM
WhiteHawk's Avatar
Car: 1991 Firebird
Engine: 350,Dart Heads,Weiand In,Roller Cam
Transmission: 2400-Stall, 700R4 w/ Kit
Axle/Gears: 4th Gen 3.42 disc (I wish)
I got a 700R4/4L60E (new rebuild, 1991 Firebird). I have a B&M kit Street/Strip, higher pressure spring, vette servo, and 2400 stall. Under very low load acceleration, trying to look normal here, it will rev to 2500 RPMs before shifting (1-2), by then it will slam the next gear when it shifts wagging the rear end sideways.
What adjustments do I need to make so people stop yelling "SHIFT!!!!" when I cruise by in town?
Not that slamming gears is good for my drivetrain :P
Old Feb 5, 2008 | 09:11 AM
Shagwell's Avatar
Car: projects.......
Re: Car won't shift at cruise, when it does, WHAM! Kit and Vette mod 700R4
sounds like the governor core is sticking. - fairly comon, do a search if you need any DIY info.
As for the bang shifts, yes it is hard on your driveline and it will take out the rear planetary in the trans. - that's why anyone who knows 700's says not to run the B&M shift kit.
Old Feb 5, 2008 | 07:45 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Have you tried readjusting the TV cable as well? Might give it a shot. I have about the same setup, and mine shifts hard, but driving like a normal dad in a Buick, it's not enough to jerk you sideways. Now when my foot's in it, it's a whole new ball game!
Old Feb 6, 2008 | 06:02 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
i would adjust the tv cable properly. then if that doesn't work, go for the govenor.
Terrell351
Jun 13, 2021 01:13 PM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
Bull86
Aug 10, 2015 05:43 PM
drathaar907
Aug 6, 2015 04:20 PM
