Can This Rear Work?
Old Feb 24, 2008 | 11:41 AM
KonArtist's Avatar
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
Can This Rear Work?
About a year ago I bought a 91Rs parts car. I only bought the car for the dash pad, cowl hood and GFXs. Well the other day I had the junkyard come by and pick whats left of the car up, but before they left I cut the rear out from under it. After I get it out and rolled it over to the shop I opened the back cover to see what kinda rear it was. When I opened it up I was kinda surprised to find what looked like brand new gear lube and what looked to be fairly brand new parts. I figured it up to be a 3.42 rear.
Now my question is, is it possible for me to swap this to my 92z? That rear is a drum rear and my Z has a Disc rear so is it possible for me to swap out the disc to the drum rear and then use it in my car?
Old Feb 24, 2008 | 11:45 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Can This Rear Work?
you could always keep your discs and just swap the carrier
Old Feb 24, 2008 | 12:27 PM
allgood's Avatar
Car: 92 WS6 Trans am convertible
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
i have a quik question for you
i hear a noise comming from my rearend but i only hear it when i drive my car in reverse.
Old Feb 25, 2008 | 08:46 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
What kind of axle is under your car now is it a 10 bolt or a 9 bolt?
Old Feb 25, 2008 | 10:23 PM
KonArtist's Avatar
Engine: 350 HSR
Axle/Gears: 3.42's
both are 10 bolts,
Is swapping the carriers out hard? Im purdy new to anything rearend related but I love learning.
Old Feb 26, 2008 | 02:42 AM
allgood's Avatar
Engine: ls 6.2
Transmission: 4l80
Axle/Gears: 2.73's
are you talkin to me?
Old Feb 26, 2008 | 05:38 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I assume the discs are PBR's. If so, they're desirable.
JamesC
Old Feb 26, 2008 | 12:50 PM
WIll36's Avatar
Engine: 355, 408
Personally if they're both 10 bolts I would just pull the axles and swap the brakes between the 2 to retain the discs in the rear. Its easy to do the axles and transfer the backing plates, because carrier and pinion swaps are far more complicated and have to be done very accurately or the rear end will destroy itself.
Old Feb 27, 2008 | 03:10 AM
Pat Hall's Avatar
It'd be dumb to mess up a perfectly good ring/pinion setup. You could just run the drums if you wanted to. However, it's really quite easy to modify the flanges on the drum rear to bolt up the disc backing plates. There's an article in the tech section that discusses how to do it. Basically you just cut off the top of the drum flange, where the big hole that the wheel cylinder brake line runs through. Then you grind a 45 on the four corners of the flange and drill the holes to where they line up with your disc backing plates.
Old Feb 27, 2008 | 05:22 AM
JamesC's Avatar
Or check out Ed Miller conversion kit.
JamesC
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
