where do i drill a hole?
Old Feb 24, 2008 | 04:49 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
im at the point in my t10 conversion where i need to cut a hole in my firewall for the "upper rod" to pass through the wall and attach to the z bar. if someone could give the location of the hole that would be great! example- 3" below brake booster and 1" to the right? thanks art
Old Feb 24, 2008 | 04:57 PM
phillip_helmet's Avatar
Car: '84 Camaro
Engine: 5.3l TSP 224r
Transmission: TH350 3600 stall
Axle/Gears: LS1 3.23
Re: where do i drill a hole?
There should be a cutout on the pad under your carpet that makes the perfect template.
Old Feb 24, 2008 | 05:07 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
there is a cut out in the floor matting down there. I know its damn near spot on for the hydraulic setup, its what i went by. i dont know if there are differences for the mechanical linkage though
Old Feb 24, 2008 | 05:49 PM
im wondering if theres a difference? i dont wana just start hacking up my firewall.
Old Feb 24, 2008 | 05:55 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
member sonix has a t10 IIRC, maybe PM him and ask
Old Feb 24, 2008 | 11:16 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Funny how I stumble on these threads....
I could measure from the firewall side, but i'm on a business trip away from my car for most of this week. Perhaps Air_adam is willing to.
Or if I come home early I can see about this.
Old Feb 24, 2008 | 11:36 PM
THANKS SONIX! youv been a huge help on my swap. when you get a chance measurments would be great! till then i will try to contact air_adam
Old Feb 25, 2008 | 12:39 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I'll try to get out to my car today or tomorrow, and I'll see what I can do
I'll take pics if I remember too.
Old Feb 25, 2008 | 12:47 PM
thanks Air_Adam!
Old Feb 26, 2008 | 10:11 AM
well, i felt a little frisky last night and took a 1/2" drill bit to my firewall. i started in the center of the area designated for clutch master cyl. then i took a sawzall and cut upward about 1.5". this produced a slot tall and wide enough for my modified upper pushrod to pass through.oh, to re-inforce my upper i just took a extra one that came with my setup, hacked the ends off, then welded them together. now this piece is STOUT!long story short...i was sucessfull .thanks to all who replied
Old Feb 26, 2008 | 12:41 PM
Air_Adam's Avatar
I was going to go get numbers for you tonight, but it looks like I don't need to dig out the car just yet. Good to hear you got it working!
Pac J
May 17, 2020 10:44 AM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
drumstixer
Sep 29, 2015 03:02 PM
